Good luck.
A buddy of mine's boy brought home his second infection - symptoms started the same day as graduation and got bad enough he got tested after the play he was in Saturday - which means the entire cast was exposed.![]()
Damn near as much as I weigh.Weighs around 265-270#
I know I would have at least one nut rolling down my pantleg, haha.Picking it up sucked.
About 10-12 years ago a buddy decided to store all his forging stuff in my barn.
For the past 2-3 years I've been using hos 290# anvil with his permission.
A month ago he asked what of the gear i was using and if i had ever repaired the blower on his farriers forge.
I told him i hadn't touched either forge, but the anvil was getting a lot of use.
He decided he wanted all of it back so it could be stored closer to home - and sent someone else to pick it all up.
This left me without a large anvil shaped object until now.
Found this piece of O6 bar stock Friday.
It's only 8" tall, but 12" in diameter. It also has sharply squared edges.
Weighs around 265-270#, cost less than $200.
Well, finally got the 'rona. Fortunately after classes and grading are done, and now I get out of graduation.
If recovery proceeds on current trajectory, it will only be a 48hr deal, but who knows.
part of my plan is to weld some square and round tubing to one side for hardys and pritchels.
Or I may just get a pecto plate and call it good that way.
haven't decided if I want to heat and quench the face or just work harden it. (leaning towards work hardening)
Rosebud until cherrypart of my plan is to weld some square and round tubing to one side for hardys and pritchels.
I got covid the last day of Octber 2020, and I still can't taste and smell everything.I had a real mild case bout a year and a half ago ... my taste and smell are still messed up big time. I hope you feel better soon with no lingering affects!
That means you can drink cheap whiskeyI got covid the last day of Octber 2020, and I still can't taste and smell everything.
Pulled the trigger on a new Bronco. Four-door manual Black Diamond with a hardtop. Let's see when it arrives.
