- Feb 2, 2012
It's a Becker. These blades are meant to be used. Indulge us, beat the **** out of it.
I think you're an exception, and I hope you'll sharpen that 7, tighten the scales, and give it another shot.
Batoning will wear any coating off. I've batoned with Beckers, Busses, Rangers, etc. They all lose their coating with batoning. Lots of friction involved.
The handles don't always come locked down as tightly as they could be. A quick check and a few turns of an Allen wrench will fix things. Also, the Loctite suggestion above is good. Just make sure it's the right Loctite. Clear fingernail polish will work too.
I think you guys may have been a little rough on him. It's not too much to ask that the screws are tightened sufficiently from the factory on a knife that costs more than $50. He should be able to take it out of the box and use it in the woods without it falling apart. Let's not allow the many great things about Beckers take away from the fact that he had legitimate issues with his. While they are easy fixes, I don't think it's fair to discount that he was dissatisfied with some of the things that happened.
Dude, its not like it "Fell Apart" there was a screw loose...simple fix. Was it a crappy thing to happen? Sure I guess, but its not like he bought a brand new Case Knife only to open it and have it fall to pieces in his hand...yeah its over a $50 knife, but compare it to similar knives and you will pay tons more...I don't think a simple thing like a loose screw would throw me off of a blade forever...Coating is coating, strip that crap off and have fun with it...sounds like he is already on his way towards that...Getting pissed off about a screw being loose in a handle is like getting pissed off that the girl you picked up in Bangkok has a package.
Couldn't have said it any better myself.Too bad you feel you had a bad experience.
Just a couple observations (and with all due respect) this is your FIRST fixed blade and you're going on a 16 day camping trip ? I guess.
Handle hardware has been known to come loose. (give you that one) But that prob. would have happened when you were using and prepping your NEW gear BEFORE going out for 16 trip ... yes ?
Battoning is Battoning. Beats up a blade. It is what it is.
Stabbing a Redwood ... Hmmmmmm Why ?
Anyway - 7 is a great knife. JMHO
I highly doubt one swing loosened a nut completely enough to lose it somewhere. Did you even check your gear before leaving for a 2 week trip? Batonning will strip the coating off any knife I have ever seen. Stabbing things dulls a blade. Weird.
They are meant to be beat on.
I call BS on this. A person spends his hard-earned money on a fixed blade which are touted as being some of the toughest on the market, and HE is at fault when the hardware comes loose because he didn't check it? Can a person reasonable be expected to check every single aspect of his equipment before he sets off? Do you check the each individual stitch on your backpack before you leave? Do you check the torque on every single lug nut on your brand new car? Do you measure the tensile strength of your shoelaces? My guess is no. You spend a good amount of money on what is supposed to be a quality piece of kit, and expect it to work.
This fanboyism "our chosen brand can do no wrong, so when it fails it must be your fault" crap is getting old.
\I call BS on this. A person spends his hard-earned money on a fixed blade which are touted as being some of the toughest on the market,
Keep in mind the value aspect of these knives- and the modification possibilities. Many will switch the handles and loctite anyway within a few months of ownership- thus making loctite really not all that neccesary IMO- plus, it's not really needed, one just needs to tighten the bolts down. and HE is at fault when the hardware comes loose because he didn't check it? Can a person reasonable be expected to check every single aspect of his equipment before he sets off?
One of my many mottos is to know your gear in every way. I personally do inspect every aspect, and I do not think that making sure that your gear is in tip top shape and checking things like screws is unreasonable in the slightest.
Do you check the each individual stitch on your backpack before you leave?I do Do you check the torque on every single lug nut on your brand new car?I have no car at the moment- but I do check. Do you measure the tensile strength of your shoelaces?As long as they feel right- I know they're tied correctly. I know the breaking point of my laces, and I know what they can take and what they can't. My guess is no.Incorrect assumption You spend a good amount of money on what is supposed to be a quality piece of kit, and expect it to work.And work it does- it did function, he just had a screw come loose, a small coating problem and the blade was a bit dulled. None were problems that hampered the function of the knife.
Making sure your equipment and gear is going to work is YOUR responsibility. That is why guys who jump pack their own chutes, guys who go scuba diving check their tanks. It is YOUR responsibility to check.Can a person reasonable be expected to check every single aspect of his equipment before he sets off?Would you rather "trust it to work" or KNOW it will. If you check it, then you KNOW it will.
Do you check the each individual stitch on your backpack before you leave? Yes, actually if I'm going on a long trip, I do check EVERY aspect of my gear
Do you check the torque on every single lug nut on your brand new car? Yes, I do. I also check that the fluids are correct, the tire pressure is correct, and the belts are correct. It is just GOOD sense.
Do you measure the tensile strength of your shoelaces? I do a pull test to make sure they won't come apart.
My guess is no. You'd be wrong
