Okay, little update here...I have been pretty busy all weekend researching the Canada France Hawaii Telescope and writing down my thoughts about John Updike, as most heavily tattooed guys with a lot of guns and knives are wont to do, but here is what I managed to do: the blade has been thinned out substantially. I BELIEVE that I am cutting about a 9-10 degree grind on the thing, and I will give you my reasoning and maybe somebody can correct me here:
I have left about o.o50" on the edge so far...I plan to take it down to about o.o25", then heat treat it, then take off the last o.o125" from each side. So the thickness on the centerline might not change much, but the three-quarter mark may thin down from o.140 down to around o.120" or so, I think. That is o.5425" back from the edge, so figuring a right angle triangle o.o60" on one side and o.5425" on the other...actually I guess I would need to know trigonometry to figure out the angle I've ground it at.
So looking at a math textbook now I see that the sine of this angle would be the hypotenuse divided by the opposite...hang on...hypotenuse is o.546"...over opposite o.o60 is 9.09.
So I believe this to mean that the general grind is about 9-10 degrees per side. That seems about right looking at the knife with a protractor.
In the second pic you can see the fairly narrow front bevel and WIDE main bevel...I am still convexing this but have taken siguy's and Scott's advice and hogged off a lot of metal on the flat platen. You can also see the centerline I scribed with a pair of calipers on day 1.
This next couple of shots show the bevels, but also the lengthwise scratches. What are they from? That is where I have been laying the blade down on a glass lapping plate and wet/dry 120 grit so I can see if I am grinding evenly. So far, so good!
And the last couple are from the tip down, showing the least finished part of the whole project! I am hesitating a bit about the tip as it's more difficult to measure and correct. I am spending nearly as much time with the digital calipers as I am with the grinder, but the tip is a little trickier. Fortunately by the time I am doing it my belts will be so worn out that mistakes will be made slowly.
I didn't have time tonight to set up a tripod and take nice pics, as it's about 1 am and I have to be up early tomorrow!
Anyway that's the weekend's work in the off hours...it is definitely coming along and all the advice has helped a lot.
Any thoughts would be appreciated. I feel like I will be approaching heat treat soon, although I will probably get the handle scales going first.
Also a quick hello to my dad who is not a member here but whom I sent a link to to come check out this thread, so if you're reading, hey dad, this knife was partly inspired by our machete discussion and has been made possible in large part by the digital calipers you gave me a couple of years ago!
Regular readers of my posts will recall that my dad was a prospector once upon a time and has been a big knowledge mine for me about the outdoors. He is also the same guy treed by black bears after he attacked them with an axe for stealing his pies in the Queen Charlottes, a remote set of islands off the Northern coast of BC, for those of you who remember me telling that story.
Anyway thanks dad and I hope you guys enjoy the update!
