- Mar 11, 2013
It’s pretty common. Reloading is more common than casting your own bullets. Here, there is no restriction as to how much ammos you can have, and only the fire code restricts powder and primer.I live in Canada and I haven't spent a lot of time around firearms. Is making your own ammunition a common thing? I've never seen it before, but I respect the DIY ethos of it greatly.
Also, I'm enjoying following along with Merle's adventures!
It’s actually quite simple. With major parts being basically,
resize the case back to standard dimensions, normally at the same time as removing the spent primer.
Flare the mouth so it doesn’t shave the edge of a new bullet, and expand the inside to a desired diameter.
Install new primer, add powder in correct amount.
Put bullet on top and seat and crimp it. And you have a fresh carrridge.
I’ll try to get a whole process sequence for you and all.
The casting your own bullets is simple too, with a bit more finesse. Melt lead in a special lead pot and pour it into the mould. Bullet drops out, size it and lube it one of several methods. Ready to load. The trick is to not have any imperfections when casting. That takes time to master. Sorta like hand sharpening a knife.
The advantage is low cost of ammo. 44 special is about $50 a box of 50. But my cast reloads are about $5. If I bought bullets it would be between $15-$25.
The other advantage is that during times of shortage, I have powder and primers to make what I need or want. Primers for 44 special also for 41 mag, 45 auto, 45 colt, 44 mag and other large bores. So if I have enough primers for say 1000 rounds, I can make whatever I need at the time, instead of having 1000 45 auto loaded but no 44 specials.
Then the hobby aspect is great. It’s fun as heck and very satisfying. Easy enough anyone can do it, but can be as complicated as you want it to be.
I know it’s legal up in Canada but not sure of the restrictions. I am Bazoo over to castboolits.gunloads and on thehighroad forums. I talk occasionally there depending on my notions. There are members there from Canada as well. If you decided you want to try it, you might find a mentor that will help you get your feet wet. That’s very common in our world; guns and reloading; mentorship. I offer the same to local people anytime I can.
Here is a free manual http://marvinstuart.com/firearm/Man...ding Handbook - 48th Edition - 2002 - ocr.pdf
It offers many details as to the what and why. But don’t take that to mean I prefer you to read that as opposed to asking me. I’m glad to answer any questions you have on the matter.
