- Mar 28, 2001
I won't add to what others have said because it's great - but I will add that my method is just what works for me. Being OCD I like seeing a nice consistent edge, I'm not referring to the widening near the tip, I mean changes in geometry and edge bevels that don't transition cleanly to the primary grind. I also don't like removing more steel than necessary so I have developed a system of setting my preferred edge on the jig, and maintaining it on croc sticks, only going back to a jig if the edge gets beyond repair.
How you position the clamp on the blade has a lot to do with the wider edge near the tip (note - wider, not an angle change). Each blade is a little different but my rule of thumb is just forward of center on a line drawn from the rear edge to the tip on a straight line.
Wicked Edge has a scale that is intended to make it easier to sharpen to same angle a second time, but my system is basically the same idea, stay consistent in thought and process and you increase repeatability. You can also start future sessions with a sharpie and polishing tape or a high grit stone to dial in the angle without affecting edge geometry as mush, then once you have it set drop to your normal starting grit.
