No offense, but after seeing my buddy's broken lock that hapoened after he stated he stabbed a tree, I won't trust an Opinel enough to try using it hard.
Lol "it was coming right at me"
Was it self defense?
IMO, a locking folder FAILs if it closes under under light to moderate closing forces and worse, if it does so unpredictably. IME, this is prone to happen in 3 primary ways:
a) Repeated hard cutting (opening forces) causes wear and tear damage to the lock assembly (common failure mode of lock backs).
b) Twisting forces on the handle and blade cause the lock assembly to deform (common to both lock backs and frame/liner locks).
c) Sand, dirt or grit foul the lock assembly (common to lock backs and frame/liner locks).
It's as simple as this. These failures don't happen on modern knives.
I've worked construction and automotive for most of my life and I would eat an Opinel in a week at any of those previous jobs. I do things like chisel, pry, scrape, hammer, and screw with my knives. Yes, I can already hear you screaming knives aren't meant for that, but what about when I find knives that can regularly do that? If the selected tool works, it works.
I can't expand on my current job due to an NDA. I will say that my most needed features of a knife are the ability to open quick and be tough as nails.
I really need to move to your planet. On earth, and the internet forums on earth, I hear testimonies and stories about all sorts of locking knife failures with modern knives. I dunno. Maybe they're all making it up.
The only thing you'll hear me say in response to this, "You're on." I'll give the Opinel to bust for free. Just sign up for the Pass Around. Very, very happy to see the knife busted under normal hard use. Intentional destruction testing is not the point. Go through it in a week? Go for it. We'll all learn something from it.
Chisel, pry, scrape, hammer and screw with the Opinel? Sure. I batton with mine all the time. I do find when really beating on them it's best to unlock the lock ring actually so it free pivots. This really minimizes the stresses on the joint and forces me to hammer on the blade in a manner that actually cuts.
Really the only caveat I can give you about the Carbone in the Pass Around is that the it is roughly speaking 1085(ish) carbon harden in the Rc56 range, which makes it pretty tough (i.e. it dents before it chips) but not particularly long lasting in terms of edge retention. The blade steel is what it is so it has pros and cons. Cutting wood hard and then hitting metal will cause dulling and maybe even a dent.
FWIW, one of the guys who turned me onto the Opinel did HVAC for years where he used a larger #9 as his primary duct cutting tool.
Opinels are easy to one hand open once you get the hang of it but not quickly. Tough?
Would love to find out their limits. I've not found them. Maybe you can? As the guys from Missouri say, "Show me!"
I've never owned a quality liner lock that I could overpower the lock by hand.
Keep your Opinel offer for now. I'll buy one next week and start off slow with it until I trust it to try the harder stuff. I'll likely go for the #8 since I work with some nasty chemicals and in heavy rain at times, and don't want to test the wood but the design itself. Unless there's any reason for me to avoid the #8?
I just got one of these over the weekend and I am impressed.
It is hard to believe how smoothly this thing opens.
Super sharp out the box, lockup at about 50%, no blade play, and fit and finish are top notch.
The only downsides are that it is not a total open frame design and it is pretty ugly IMO.
But this is going to be a work knife so I may be able to take out the plastic liner to open it up and for 25 bucks I may get used to its looks.
Great knife for small money.
No offense, but after seeing my buddy's broken lock that hapoened after he stated he stabbed a tree, I won't trust an Opinel enough to try using it hard. The Opinel is a great old time pocket knife, but i won't take up that offer for the things I do with knives simply for my own safety.
https://www.youtube.com/watch?v=1qKuZskDzmU&feature=youtube_gdata_player
https://www.youtube.com/watch?v=rIKJxGhZC0U&feature=youtube_gdata_player
I don't know what he's saying, but I like the way he thinks. Most knives should be capable of this, but I couldn't find many hard use tests on YT.
https://www.youtube.com/watch?v=SUUbUaaxprU&feature=youtube_gdata_player
Just to update, I tried an Opinel, I believe the #8 is what I ordered. I cut some paper and rope and that was all I needed. It was very unergonomic, and felt like a flimsy folding fillet knife. I gave it away to my brother in law. I'm sure it's a great utility onife, but with in the first 30 seconds I knew I didn't want to trust my life to it, especially in a defensive purpose.
Mu Utilitac just gets beat on more and more. It's even more beat up than this now. Lots of prying, but I onpy had to adjust the tension once which was when I first got it. I freaking love this knife and my 0350 and Vantage have been shelved.
