center is a bitty rang
I think I'll have to put a bitty rang on order for penance!I guess I spoke too soon calling you friend earlier. That is the Fried Liver Attack. And now you’ll have to watch your back.
Nah, just my kiddos markersIs that a drop of blood between the FLA and sharkbite?
Both about a 3” blade. For me, that is the optimal length for pocket carry.
The discrete carry concepts clips are the best pocket clip I've used. They accommodate thicker pockets than an ulti-clip, hold on to the pocket basically just as well as the ulti-clip and they cost less as well.Can someone explain to me the purpose of a pocket sheath clip?
I understand it's for keeping everything secure in pocket, but the ones I have tested are a pain to unsheath/sheath while clipped. The ulti style clips work the best for this purpose, but they literally shred my pants.
I see a lot of the lighter weight clips and I wonder how they are staying put when unsheathing the knife.
I am very picky in what I like for a pocket sheath. If you look at the pics navman posted, his sheath uses a Discreet Carry Concepts (https://discreetcarryconcepts.com/) clip on his sheath. On that clip, you can see a tooth that bends inward. The tooth makes it grip better. That is what makes it work better. The pic Hammer67 posted shows a clip without that tooth. It is fine on my folders, because I want to pull the whole folder out with the clip. On a fixed blade I want the knife to leave the sheath behind when I draw. Clip is only one part. The sheath retention is also important. If there is too much then you are pulling the sheath out with the knife no matter what.Can someone explain to me the purpose of a pocket sheath clip?
....The pic Hammer67 posted shows a clip without that tooth. It is fine on my folders, because I want to pull the whole folder out with the clip. On a fixed blade I want the knife to leave the sheath behind when I draw. Clip is only one part. The sheath retention is also important. If there is too much then you are pulling the sheath out with the knife no matter what.
