- Aug 29, 2010
^YesssssHonestly I would rather see a nice flat ground kitchen knife than a hollow ground blade.
If you consider the cross section of a hollow grind, it really takes a lot of thickness out of a lot of the main bevel. Basically behind the edge, half way up the blade you end up with a very thin steel (which helps the initial cut by reducing resistance) and it leaves you a thick spine to keep strength, they slice reallllly well.I don't see what benefit a hollow ground blade would have, other than aesthetics for some.
A Convex grind kind of does the opposite, it puts more thickness towards the edge for strength.
A Full Flat does everything well in my opinion. Not the best at one, but good at them all.
