I've noticed several comments about gritty action. It has been my experience that if a Queen knife has gritty action, a good flush and lube job yields little to no improvement. The grittiness appears to be caused primarily by the rough surfaces of the tang, not dirt and grime.
What kind of results are you folks getting? Does the action smooth out for you with a little elbow grease?
But, one thing I haven't heard, that caught my attention right away, was how thin the blades are. In order to fit them all in the allotted space they have been ground wafer thin. The screw driver is so thin I'd be very curious as to what screw it would actually fit to turn. The width of the blade doesn't match the thinness of it. And, it won't surprise me if the bottle opener penetrates the bottle cap, when in use. The awl is very sharp and thin. The can opener, if it doesn't break, off should shear a can top easily. The bolsters, liners and bail are very stout. Mine has no obvious gaps in the liners and the pins are flat and smooth.
If only GEC did traditional 4-blade scout patterns.
Ill have to agree re Victorinoxs consistent excellence. My several 93mm alox models just dont have these problem described in this thread regarding the QCC #99. The Vic 93mm alox models have thicker tools too. And you can get a Vic 93mm alox for 1/4 to 1/3 the price of the Queen. $100 for a scout pattern is a lot of money!You don't know that. My 5 Pioneers, 3 Farmers, Electrician and 4 Cadets could be a fluke. Same goes for my 5 Wenger SI's.Although Victorinox manages to do it consistently without issue.Like I said earlier, 4 tools is a lot to cram into one folder without something messing up.![]()
