Back around 2004 at the BLADE show, Ron Newton (Ms) explained to me how he did bedded tangs and at that time, he was using bearing grease as a release.
Sometime later I heard of guys using Vaseline.
Both methods worked for me, but I always got kind of a funky "bed" left in the cavity with those.
I saw in one of John White's awesome WIPs, that he used the paste wax. I have used the wax as a final step on my handles for years, so I gave it a shot. For ME, it has worked so much nicer. Big THANK YOU to my friend John for sharing this.
:thumbup:
I don't know if there's a right or wrong way, but here are a few things I do----
-be SURE the all parts fit together nice and tight BEFORE bedding. This is not the kind of thing where you say, "Well, it almost fits tight, I'll adjust it after it has been bedded." That is just asking for trouble!
- do a dry run INCLUDING the clamp-up before putting epoxy anywhere. I promise you, if you don't, something will go wrong and it will come back to bite you.
- make sure the tang is smooth (I prefer to have any sanding marks running with the tang just to be on the safe side)
- do not drill the tang pin hole before bedding, it will just create a small cavity for the epoxy to try and find its way into.
- clean all the parts thoroughly, then apply the wax with my finger or a Q-tip. I like the finger method because the heat from my finger makes the wax melt a little which allows a nice, thin coat.
- apply wax to everything you DON'T want the Acraglas to bond to
- I mix the Acraglas in a plastic condiment cup from WalMart under a heat lamp. It makes it nice and smooth---and runny.
You can squeeze the plastic cup on the rim, so that the epoxy can be poured right down into the center of the tang hole. This is where being sloppy will only make things harder. I don't fill the hole to where it's pouring out the top. I pour enough in so that WITH THE TANG in there, it will fill the hole ALMOST to the top of the block. There is no reason to put so much in that it gets forced up into the spacers and out all over the handle.
I have heard of a lot of guys using 5 minute epoxy to do this. I won't use 5 minute epoxy for my normal bonding needs, because it breaks down much easier/faster than slow set epoxy... so I won't use it for bedding purposes either.
The wax+Acraglas combo will give you a cavity that fits the tang LIKE A GLOVE.
I found some pics I took while doing this stuff to an integral.
