Now THAT is cool. I'm building one. Thanks, Nick!
I like the idea of this gizmo. As I just though about making one I wonder why you couldn't just chuck a dremel cutoff wheel in a drill press and raise the table to the height you want?
Thanks guys.
Patrice- like you said, jigs and fixtures and doo-dads are cool.![]()
To be brutally honest... a lot of the little gizmos that I make are a direct result of ADD. I will be in the middle of something, and my brain will drift away from THE task right in front of me, to ideas on how I could do the task a little easier/better... or often-times, more COMFORTABLY. That's why I have so many different sanding blocks/sticks. Sure, I could do everything with a couple different blocks... but having a stash of them makes thing easier, more comfortable, and most importantly for ME... easier to stay focused and on track. Sometimes a little diversion in my time helps keep me from TOTALLY derailing from what I'm doing.---- It's much akin to a person that's dieting allowing him/herself to have a candy bar once every two weeks and it being just enough to keep them from just going to Baskin Robbins and eating all 31 flavors and blowing their diet to hell... LMAO
As per my set-up for the line cuts. A drill press will work, that's how I originally started doing it. But this set-up, with the Foredom, V-block, and top-plate, is super easy to adjust to just the heights I want, has no run-out (which is extremely important when you're using a 0.009" thick separating disc!!!), and it is VERY easy to get close to it so that I can see what I'm doing. I also really like having the luxury of the foot pedal to start, stop, slow-down/speed-up the cutting disc.
