So far so good...![]()
The orange thing is an EDM stone. You can get them at just about any mail order tool supply outfit. I bought all of mine from moldshoptools dot com. Really great people there.
I really don't like using them, because you need to use a cutting lubricant- it can be water, WD-40, dedicated stone oil, etc... but it makes a slurry all over the part and makes it impossible to see what you're doing. That's based on my self taught experience. A guy who was actually taught how to use them might know a lot better approach than I do.
The handle block has been bedded to the tang. AFTER all the spacers were fit, index pins and screws applied, and the handle block made to mate up to them with a gap-free fit (btw- -the pins go through all 3 spacers and into the wood block) I coat the tang with Johnson's paste wax (THANKS John White!) I used to use grease, the wax works much better. Then put the handle together with Acraglas and clamp it together overnight.
That's what was going on in the very first pic.
The next day I put the blade securely in a vise, and knock the handle block off with a piece of wood and a hammer.
After that, you clean up the wax, and the handle will go back on to the exact same spot, every time.
This allows you to put the handle and spacer stack on the knife withOUT the guard, and they will still seat where you want them too.
The black tape is just to keep me off the spacers while hogging handle material off. After I get fairly close to the spacers, and the shape I'm after, I typically put three layers of pinstripe tape on the spacer and hand finish the wood down to that level.
Clear as mud right?:foot:
