trevitrace
- Jul 21, 2013
^^ Is that a rip off of the bagel bites jingle?
One hydrogen atom said to another, I think I lost my electron. Are you sure? Yes, I'm positive...Did you hear the one about the chemical engineer who fell into the eighth stack on the olefin reactor? He was badly butylated
No wonder she didn't get it. 4 wires going into the 3 phase motor.
will you explain this so I can laugh too?The little single phase motor looked up at the big three-phase motor and said "how come you have three wires going into you but I only have two wires going into me?"
And the big three phase motor looked down at the little single phase motor and said "don't worry, that's just a phase that's going through you"
The fourth wire does not go into the motor, It terminates in the box. It is merely a frame ground and does not carry current
"Shouldn't" be carrying currentThe fourth wire does not go into the motor, It terminates in the box. It is merely a frame ground and does not carry current
"Shouldn't" be carrying current![]()
Ugh...Leafpocalypsewho is ready for the fall of the year?
All good as long as the phases are in sync and Voltages on par.
Three-phase motor doesn't use a neutral. In fact, with the floating neutral you can have two legs that are 120 to ground and a third leg that is 208 to ground, and they will be 240 leg to leg if you're on Delta 3 phase
