Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
Delta 3 phase won't generate current on ground on any regular three-phase motor that I have ever worked with but you would certainly generate current on a wye wound motor using a neutral center tap like a generator.
If you were to take this Delta 3 phase and run it through a wye Delta transformer with a center tap bonded to ground I think you would probably generate about 138 volts to ground if I'm remembering right. And yeah, a set up like that would generate power on ground. Neutral actually, but they're the same here.
Delta 3 phase does not have a neutral and the ground is just to the frame. The vast vast majority of three-phase motors do not use a fourth wire (except externally as a chassis ground) but I guess there is probably some such as generators that do?
But still, I would expect that kind of a generator to have a separate neutral and chassis ground.
