- Sep 4, 2011
Damn you are having a rough few daysI thought today was supposed to be a holiday.
Instead, I find the downstairs commode not draining properly. Try plunger and snake. No joy.
I had the septic pumped in January, and I pulled the filter in June and everything was fine...though I hosed the filter anyway. So, I figure it can't be that.
Open the risers on the septic and up comes a mini geyser and it appears the filter must have been somewhat clogged...since the level immediately went back down as the effluent ran to the distribution box and lines when I pulled the filter.
Hosed it off, buttoned back up and decontaminated myself in the shower for a good long while.
I'm thinking that the non-stop rain over the past couple of months has the drain field pretty saturated which would slow the rate of flow through the filter to the box and then the lines out to the field.
I guess I'll start pulling it every three months as a precaution. Been a pretty shitty 24 hours. Quite literally, I guess.
I hope everything smooths out and you have a very long run of good days!
