SharpBits
- Apr 26, 2002
This is a fun site view for those who haven’t seen it before: https://www.fairbairnsykesfightingknives.com/
FlamingView attachment 2966300View attachment 2966301
The Flaming Sodomizer Rapeier. For committing acts of insecticide? Maybe?
Flaming
Awesome
Wasp
Knife
(That) Sodemizes
You should run them extra HARD for name effect lol
The all brass handle was not part of the original design. It was done by some manufacturers to lower costs by using a cast handle.
All valid points!The physical samples that I have handled that were original genuine issue did not have a thin tip. They were reinforced. Could have been better, but I have seen way worse.
But the 1/8" tang and round narrow handle are no bueno. The handle should never be round.
The center of gravity specified in the design print, and confirmed in my model, is incorrect. Too far back. Also, all the weight in the middle of the blade and none on the ends is not good for a stabbing weapon. Many of these had a round cast brass handle. Brass is 10 times heavier than wood. It's putting a lot of weight in exactly the wrong place.
Here is a knife whose edge cannot be indexed by the handle, you have no idea where the edge is at by feel, and it's heavy but also unstable. Given the physical design envelope of a dagger, there's only so much that a designer can do, but they didn't even attempt to do any of the things.
Also, it's heavy, yet weak.
It's a cool dagger. Perhaps in part due to the history and the time and place where it was being used. But it is suboptimal.
Yes, correct. I misread it and it was the ringed alloy handles that were the cheaper and worse alternative.Pretty sure they started out with knurled brass but had to change to something else. Some kind of pot metal or maybe aluminum because the brass was in short supply and the designers lamented the loss of that heavy ass metal. Idunno.
for today's throat stabbing tool, I suggest titanium with a carbide pommelPretty sure they started out with knurled brass but had to change to something else. Some kind of pot metal or maybe aluminum because the brass was in short supply and the designers lamented the loss of that heavy ass metal. Idunno.
In any event, the original balance, that was selected based on real world experience on the streets of Shanghai, was changed for the worse.
Edited: so many typos
Laugh all you want, but Fairbairn lived the life and did the deeds. He died an old man in a field where most die young.
