Synov
- Jan 21, 2023
So you just described how they use our tax dollars i think.Well, here's the situation right?
You want heat in your house
So the power plant is going to take the heat, from burning coal
The heat that you want
And use it to boil water into steam.
Due to the latent heat of water, it takes a lot of energy to boil water
That energy is largely just lost
And then they use the steam pressure to turn a turbine
A lot of that energy is lost too
And then this turbine converts rotational mechanical energy into electrical energy. This step is actually pretty efficient.
And then it is transmitted along power lines to your house, with some loss
Where you take all of this carefully crafted electricity and subject it to a controlled short-circuit to make the heat that you wanted. That was present in the coal in the first place. But you threw most of it away.
Electric resistive heat is ironic because it is both 100% efficient and also the least efficient use of electricity possible, because it does no work other than create heat.
Isnt nuclear energy just steam pushing a turbine around?I like the fact that, at the end of the day, the most efficient way to get energy — literally for anything — is just to burn something.
And you know what’s even funnier?
That’s pretty much how it’s gonna stay, no matter how much time passes
Nuclear energy is solid too.
Basically, it’s just explosions, right?
You get what I mean?
Burning something or exploding something — that’s essentially the best energy.
By the way, back in 2022–2023 I bought shares in a uranium energy company, and they went up almost 8 times.
No joke, I genuinely think the real future is nuclear energy.
Sure, it can blow up, but damn, even Homer Simpson managed to handle it all.
I’d trust the safety management to someone like:
tinfoil hat timmy
Hey, you already know way more than I do.Isnt nuclear energy just steam pushing a turbine around?
They dip uranium in water and it boils the water and creates steam?
Am I wrong?
I wouldnt doubt it.
Unless I buy into it then watch the sector fall into a black hole financiallyHey, you already know way more than I do.
I’ve always known and still know this is the future.
It’s definitely better than solar.
And cleaner than any other energy source.
Relax — this much knowledge is plenty to handle safety at one of these plants.
Thanks E !Glad everything's okay, Yoko. Take the night off.
Murica!!!
