Ankerson
Knife and Computer Geek
MR. Ankerson, Have you ever tested Laminated VG-10 as found on a Falkniven F1? Curious to hear if it's better than normal VG-10.
Why would it make any difference in this test?
I dunno. I've just heard the claim that it's better?
Thanks, I understand. I was sort of hoping one of those Metallurgists that seem to hang out in this thread might know something about it and maybe say something.Jim's a man of few words.What he means is is that in this test, which tests cutting, you're testing the VG-10 edge whether or not it's laminated. There may be benefits or detriments for other purposes, but not when just comparing edge retention.
Thanks, I understand. I was sort of hoping one of those Metallurgists that seem to hang out in this thread might know something about it and maybe say something.![]()
Oh, you should have said so. They (whoever said its better) probably means it's more bendable and less prone to gross failure. Soft laminate sides will allow a blade to bend easier, but won't break. Laminating it won't have anything to do with edge retention, or much of anything else once you get past the lamination lines.
Thanks.Oh, you should have said so. They (whoever said its better) probably means it's more bendable and less prone to gross failure. Soft laminate sides will allow a blade to bend easier, but won't break. Laminating it won't have anything to do with edge retention, or much of anything else once you get past the lamination lines.
Looking at the difference between the S110V Manix before and after the regrind, I'm wondering how much of the difference between the two Cruwear tests could be attributed to geometry and how much to heat treat. I think it would be interesting to test a Cruwear Military that was reground to .005" behind the edge and see what kind of difference one would see compared to the original.
Forgive me if this has been discussed already. I've been away for a minute and the 2,000+ posts in this epic thread are a lot to wade through.
Theres a guy on yoh tube, Ruslan Kiyasov. Hes the Russian equivalent of you Jim, does a lot of tests, test different steels and whats important, hevknows a thing or 2 about sharpening. He had a Phil Wilson in cpm 10v and he got to 1600 cuts before he couldn't cut anymore because his arm was tired. He tested the knife and it cut printer paper like nothing happened almost. You should chech out his video/channel, a lit of his vudeis have subtitles now I think. Im anxious to see what results you get but I feel bad for you cuz 10v is a beast by itself, give it a custom heat treat and a geometry suited for cutting and who kniws wherd it will end up. Thank you fir all your tests and im excited to see wgat cones of that knife.
That doesn't surprise me, I have one of his here in K294 that did 1800.... 64 HRC, 10 DPS and .010" behind the edge.
Unreal performance... :thumbup::thumbup::thumbup:
My arm hurts just thinking about that many cuts.![]()
Im pretty sure his was at 15 dps. He cuts jute rope instead on manilla to test overall edge holding and then uses a thinner manilla rope to test the apex of the knife, stopping every 10 cuts and cuttinf rope to check for deformation. One thing I find surprising is how "bad" cts xhp dud in the 400 grit test. I would've thought it would surpass s30v because in my testing and in Ruslans videis it had much better wear resistance than s30v. Do you think xhp doesn't like a coarse finish, since in the 6k test it was a group or 2 higher than s30?
I can offer a reason for CTS-XHP performance in 400grit finishing rankings.
Here the type of carbides really counts given that the HRC value ensures good edge stability and penetration resistance.
Best performances belong to steels having MC carbides (Vanadium and also Niobium for S110V) and M2C Wolframium based carbides (CPM-M4) which are remarkably harder than Cr carbides (either M23C6 or M7C3).
CTS-HXP @60.5 has only M7C3 Cr carbides and maybe even a small amount of M23C6 (softer) Cr ones. But it can reach 64HRC with 62 being a safe zone, so at 60.5 CTS-XHP is not delivering his own optimal edge stability as well.
S30V at 60 is pretty close to its max working hardness (62) and I know only one production maker that routinely trespass 60: Fantoni, from Maniago, Italy.
Elmax Mule at 58.5 does even worse than CTS_XHP, because edge stability will be a PITA. I've one![]()
I don't think people quite understand how much of an impact being at or near optimal hardness can make in performance.
That's one of the main reasons why I stated adding the customs into the list in the coarse edge section introducing both thin blade geometry and blades in the higher hardness ranges so people can see the effects....
I tried to find if this question had been covered and I didn't find it. Jim, most of us are pretty good blade sharpeners, but I am concerned with super hard steels that hand sharpening is accurate enough. Id there a blade sharpened for hard steel that is variable in angle and reliable for a fine edge? If this hasn't been covered, hopefully it will be of interest. Thanks.
