I am not understanding the question...![]()
I was asking if you would give your opinion for a good blade sharpener, one that will sharpen hard steels at various angles. Thanks
Very good information. Yes exactly what I was asking. Thank you both Jim and daberti for your help.
That's right in the range we discussed or maybe slightly better. I've been wanting to try some for a while. Gonna have to get around to it soon.
That 4V is nice. Well rounded performance if corrosion isn't a problem. I like the performance of Z-Wear/Cru-wear/PD1 class steels. Personally I would give up some corrosion resistance for wear,strength,toughness unless around salt water. I have some 3v I'm working on that I hope to get to 60-61 rc and see how it performs with a thin edge.Believe it if not, I haven't owned or tested any 3v to date.
Its there #2 overall iircWhat about that sweet Spydie K2 in CPM10V?...![]()
I don't see it on the list.
I figured that a good example of 4V would rank up that high. I'm sure it's considerably tougher than the few knives that have higher edge retention, probably tougher than several below it, too. Hopefully we can see where it falls with a polished edge, too.
I don't test polished edges anymore, the knife is gone back to Chris.
... Some of the steels appear to perform better with a polished edge or worse with a coarse edge. ...
Did any of the steels perform "better with a polished edge"?? I simply assumed that they all performed worse in this test, polishing the edges had the effect of bringing the performances closer together so that abrasion-resistance was less noticeable. Using a coarse edge potentiates the effect of abrasion-resistance, so long as you avoid leaving the edge so coarse that it crumbles - e.g. in CATRA tests of various steels cutting silica-embedded cards, 325-grit (45um) was behind 600 grit (25um), while 8000 grit (3um) was also behind 600 grit. Jim is using 400 grit ~37um. I can't remember how many cuts each steel was making before that change...
Edges that are done correctly on a stone or diamond plate have more precise bevels, are easier to maintain and are higher performance overall. With that said, I'm talking about efficient slicing knives like Jim is testing. Choppers and large camp knives are another story as you would be there all week putting an edge bevel on .035" thick section.
