- Aug 12, 2010
The Manix 2 S90V was on loan for the testing and had pretty low angle edge bevel on it so I had to put a Micro Bevel on it to get a 30 degree inclusive edge. It also had been sharpened a few times too from that it looked like. I would have had to remove a lot more steel to back the edge up.
The same thing that happened between the 2 Endura 4's in ZDP that I had cut with, one was micro beveled and worn a bit and the other was new. Big difference between them.
So in short the difference was the thickness of the steel behind the edge, one of the reasons why I try and get all the blades as close as I can to the same to make things as even as I can get them.
When I was testing it it seemed like it wanted to do better, you can tell when you cut enough that a steel should be doing better, you get a feel for it after awhile.
So in the end S90V is in two Categories, I will have the Military and Para 2 RC tested and the results will be added once I find out what they are. Both knives ended up with the exact same result, number of cuts to 20 LBS of downforce.
I will remove the Manix 2 from the list once I get the RC testing data back.
Let me make sure I understand this right. The knife with the edge thinned out more and then a 30 degree microbevel put on it, did NOT perform as well. It would have performed better with just a straight 30 degree edge?
