- Sep 3, 2006
Thanks again Jim. Love this thread.
Ankerson, I really do appreciate the studies you have done for the benefit of everyone who appreciates the steel used in their knives. I have many d2 knives and I love them, however, I would like to have the hardest steel knife that can be bought. Would you think a rex123 or maybe a d 3, d5 or something else? This would be a novelty for me but I have no idea where such a knife as you will suggest can be bought. Thank you for you answer and insight.
Ankerson, your work is HIGHLY appreciated here.
Ijust wonder if you have some data on A2 steel (CRK Shadow IV owned here).
Thanks in advance
Haven't got my hands on anything thin enough to test, A2 is a good steel for harder use knives, but as with most of the lower alloy steels they don't do quite as well in this type of test.![]()
Determining the exact carbide type sounds like a job for a lab with an Xray diffractometer.Thanks Ankerson. It was just a curiosity of mine.
I just hope CRK HT had brought about only M7C3 primary Cr carbides and not also M23C6 weaker ones.
I've seen HAP40, but HAP72 looks like a beast, has anyone used these Hitachi alloys? Hitachi seems so committed to clean alloys and fine grain that they would be great to compare to Bohler and Carpenter.
The Cobalt content is through the roof in all HAP steels, do you guys think is beneficial compared to the western equivalent?
What aboug mpl 1? I know it has 3.75% carbon, 24% chromium(I think), tungsten and around 15% vanadium. At 52 hrc it has 1.5 times wear resistance of s90v at 60 hrc and at 67 hrc it almost 3 times as much. When heat treated its 48% carbide. I hear its a bitch to work with since it only comes in round stock, dont know why its like that, maybe its too brittle to roll out. It would be a novelty knife since it would be extremely brittle. I think a properly heat treated and ground s110v, s125v, 10v and 15v are wzy more than enough for even the snobiest steel snob. Hell ive had my s110v manix lwt and I havent had to strop it yet. Although its seen less time since I got my elmax para 2(love that knive). Ive wanted to try out elmax for a while now but didnt want it from, zt, lion steel or fox and ive hoped for a spyderco elmax blade(wish it was a military though, ahh) and they came through and im really impressed. Cut up a bunch of cardboard and the edge was still shaving sharp. Way to go spyderco.
s125v has a proven history for chipping and S110V isn't a candy either.
10v and 15v are good for a fillet knive, maybe a skinner.
Remaining in Crucible realm maybe the best possible compromise between acceptable toughness and very good edge retention is CPM-M4 IMHO.
But then why carbon steel when M390 at >=61HRC can give same toughness, slightly more edge retention, finer grain, less inclusions and stain resistance?
In first post Ankerson sadly says "The Custom Phil Wilson knives in M390 (62) and ELMAX (62) are not added to the data, they wouldn't fit into any of the Categories due to the Optimal HT and cutting ability, the difference is off the scale percentage wise so it wasn't added.
I wish it was instead...
S125V isn't chippy when heat treated properly, the problem with S125V is working with it making knife blades out of it, but once the blades are made it's fine, extremely hard to work with and expensive.....
CPM 15V hasn't been used enough in knife blades to really know all that much about it.
CPM 10V isn't chippy at all, it's an extremely strong steel with extremely high compression strength, it's been around since 1978....
CPM S110V isn't chippy either, excellent steel all the way around... Now that Spyderco is using it we will see a lot more of it out there so people can see what it will really do.
There is a lot of bad information floating around about S110V and 10V (A11), hopefully that will get cleared up in the future, it's already started as those who have gotten their hands on the S110V Manix 2 and are using them have reported very positive results. That's contrary to what some what people to believe for a variety of reasons.
As with any steel the heat treatment and tempering processes have to be correct.
Who told you this?S125v is no longer available.
Where did you get this information?Good news are that Latrobe took over Crucible after bankruptcy and Carpenter took over Latrobe.
Every knife steel will chip/microchip. Even when optimally HTd for its meant use.
Compression strength it is strictly related with hardness, toughness is quite another story to be told though.
I have yet to see a chopper/hard use/all round camping/trekking fixed blade knife made out of s110v, s125v, 10v or 15v.
They simply won't trespass even 35J of toughness.
Somewhere Crucible itself said that when toughness comes into play, 3v might perform better (in edge holding) than 10v due to microchipping issues.
...3rd generation PM production facilities, which advantages are well known...
.Every knife choosen to trespass roughly 40j of toughness with >=61Hrc, based on my experience (military service in Alpine Corps included). This way the range of possible steels narrows down quite a bit![]()
