It's at 62 RC and .006" behind the edge and 10 DPS.....
I have tested it more than a few times and it does well, just haven't ran it at 15 DPS for the current testing...
Thanks Ankerson for your reply. Agreed about not testing then
Thanks Jim, I wasn't sure whether it was "POWER" or "PARTICLE" metallurgy. It seems "PARTICLE" gets the nod here.Not Chuck but yes....
Right Off the website...
1970 CPM (Crucible Particle Metallurgy) process developed
https://www.crucible.com/History.aspx?c=7
Chiral, M390 and Elmax can achieve 43J of toughness. The first in the low tempering range the second in secondary hardening range. High austenitizing, oil quenching.
Rather the opposite it is true: HT 440C at 1000°C and then at 1100°C. I can prove it to you that the latter will be by far more stain resistant because more Cr will be left in solid solution. This is even more true for AISI 618 steels, like CM154, ATS34, CPM154, RWL34, CTS-BD4P. In this case austenitizing temps higher than roughly 1050°C will bring about the dissolution of M32C6 softer primary Cr carbides.
The fact is that knifemakers other than custom makers just want to mass produce, which means mass heat treat.
They mention superduper steel for the blade, then they underharden, which makes the blade softer, NOT tougher. The edge will turn and not break. But you'll be throwing away your money.
Every steel has its own use in cutlery. And has its own HT range which can favour edge holding a little bit, or toughness a little bit.
But let me say that selling folders in S35VN hardened below 60HRC has NOTHING to do with improving toughness. If you have to harden at 57-<59 either you've chosen the wrong steel or you're laughing at your own customers.
An Italian knifemaker (factory) sells a knife with Elmax blade @59HRC.
I could go on forever mentioning CTS-XHP @60.5HRC. Easily arguable that no deep freeze (so important in this steel) has been done.
No buddy, no excuse. We deserve what we pay for and Ankerson's work is so precious to this extent.
This is incorrect.
1st Generation = Powdered Metal
2nd Generation = Very Fine Powdered Metal
3rd Generation = Extremely Clean Very Fine Powdered Metal
Every steel company representative I've spoken to defined or agrees with the definition above. If the steel companies agree, knife collectors should agree.
Chuck
I'm curious about the criticism of Chris Reeve's heat treat of S35VN, which seems to mirror the criticism of his heat treat of S30V. The hardness that Chris Reeve uses for S35VN is 58-59 HRc. Crucible recommends 58-61 HRc. Spyderco chose a hardness of 59 HRc on its mule. And other top makers use heat treats that produce similar hardness levels on that steel. For example, Spartan Blades runs its S35VN at 58-60 HRc.
I'll add that Shirogorov, which is highly regarded for its excellent heat treats of various steels, runs S35VN at 59-60 HRc.
I don't know how the peaks of toughness and strength vary with hardness, but it seems safe to assume that S35VN at 59 HRc will be tougher and easier to sharpen than it will be at 62 HRc. Wear resistance will probably drop. So it becomes a question of what you want.
Jim's tests and Hardheart's CATRA tests show that more acute edges can improve wear resistance when cutting rope, and Reeve tends to use pretty aggressive blade geometry on his pocket knives. My Sebenza in S30V at 58-59 HRc is 0.017 inches at the edge shoulders, which which front a thin, hollow ground blade. It tends to hold its edge well.
At the softer range, with good edge geometry to back it up, the Sebenza can cut extremely well, hold its edge well, be easy to resharpen, all while provided a tough edge resistant to chipping. The edge geometry and the steel carbides give a boost to wear resistance that make up for the softer heat treat.
I know there is a YouTube video out that found exceptionally poor results of a Reeve S35VN knife, but my understanding is that that test was flawed, although it has proven to have long legs on the internet. We've seen similar criticism of Elmax, which in my experience is an excellent steel.
The owner of Wicked Edge speculated that people have difficulty switching from the Sebenza's convex edge to a straight edge, basically leaving a wire edge that would give the appearance that the steel cannot hold an edge well.
Who knows what is really going on, but if there is solid evidence that S35VN at 59 HRc is some how a horrible choice, I'd like to see it. I haven't been able to find that evidence.
S35VN is a horrible choice against other SS, count Elmax, CTS-204P and M390 in. In toughness, in edge holding, in stain resistance, less finer grain, in PM technology.
Underhardening a dated and inferior steel does NOT improve toughness, let edge stability and edge holding alone.
Will eventually soften the blade, giving way to wire edge, that why Sebbies have convex edge and when you try to put a straight edge you score a wire edge.
Per Catra results S35VN needs an additional HRC point (62) to deliver as much as S30V at 61, so, sorry, this is the evidence you were looking for.
Beyond mere edge holding underhardening means that austenitizing temp is a lower than the one needed to achieve the optimal Primary carbides' dissolution (M23C6 mainly) thus bringing about less C free for hardness AND Cr in solid solution to stain resistance extents.
It all a matter of saving furnace and tooling costs.
Most of us are knowledgeable about sharpening an higly alloyed and high HRC blade. And able to choose among steels....the rest is bullshitting
While I would agree that knife knuts' purchases are a small percentage of knives bought by the general public, a knife that's over $400 or more is probably marketed to buyers who know a little bit more. IMO, there's no excuse for a knife that costs that much to exhibit poor cutting performance or poor edge retention.
I had a few expensive knives that didn't cut as well as some mass produced cheap ones, and I got rid of them quickly.
IMHO the best knife in current CRK line is the Impofu http://www.chrisreeve.com/Impofu which has the proper steel and HT for the proper task.
I don't know in USA, but here in Italy a Large Sebbie with no bells and whistles costs 610EUR!!!! Per Ankerson's results S35VN at 59 has same edge holding of N690.....
Thanks for those thoughts and your expertise, Daberti. I've never used S35VN, so all I have to go on is the experience of others. I, too, would take Elmax and M390 or one of its variants over S35VN, but I have also seen a lot of excellent knife makers swearing by S35VN, even at sub-60 Rockwell hardness. It's difficult for me to believe that Chris Reeve, Sal Glesser, Shirogorov Knives, Spartan Knives and others are so far off on heat treat. Sal, in particular, has shown that he is more than willing to take hardness levels up pretty high and geometry down, especially for knives sold to the general public, so manufacturing costs of a higher heat treat are not the issue.
Chris Reeve's Impofu would be a beast at any reasonable heat treat. It's a giant slab of 3V steel well more than a quarter inch thick. He still runs it at what seems to be for him the sweet spot of hardness: 58-60 Rc. The mystery of that knife for me is what would it be used for. Chris seems to like large knives that are thick. His chef's knife in S35VN was dismissed by some expert reviewers, but not because of the steel or heat treat, but because the blade was too thick.
I watched the YouTube video on which the S35VN Sebenza failed after cutting rope. The whole edge bevel bent over, not just a wire edge. Who knows what that was about, but that experience is certainly not common. Chris Reeve puts a proprietary convex edge on the Sebanza, an edge geometry that he says took him 6 months to perfect. So someone comes along and converts it to a straight edge -- a conversion with well-known risks -- and who knows what happened. We never got a decent analysis of why that blade failed, just another internet legend of a supposedly bad steel.
Do you have any tests or links that you could share that show toughness of S35VN does not improve when the hardness is dropped from 62 Rc to 59 Rc?
There is a tendency for people to look for either the toughest steel ever known or for the steel that has the greatest wear resistance ever known -- usually without regard to the actual tasks a knife needs to perform. Here's a shot of a blade I had professionally hardened by a well-known expert. He took Benchmade's CMP M4 blade at 59 Rc up to 64 Rc. When I was putting the knife back together, the blade was a bit off center, so I tried adjusting it with just hand pressure exerted laterally against the blade. The blade was so brittle, that it shattered into three pieces. Wear resistance matters. So does toughness.
Taking CPM-M4 up to 64HRC can be made with a variety of combinations mate. It depends also on quenching media (salt bath, oil): what quenching media did he use?
Did he follow the CCT timings during quenching?
Did he do air quenching instead?
Most probably he made some mistake in the quenching and/or tempering phase.
