Yeah. I'm still thinking of adding one back in. Out of curiosity, do you know anyone who has actually had to use one for field stitiching (skin) and managed it without say a multitool or tweezers?The cool thing about sutures is they can be used to repair clothing, get splinters out, fishing kits and a whole lot of other non-surgical uses. I suggest one in any small pocket kit.
I find the small one beds all over the shop and breaks at the hinge quite easily, particularly if you need to cut wire of any thickness. I would love a RAT branded bigger saw, even though I already have a stack of Tops ones. In fack, I'd love to be able to buy additional items, particularily a replacement meds pack. Then I could double up on a few items.I actually like the smaller saw better than the TOPS saw.
I find they ping off into the wilderness when I do that. Maybe I lack finesse, So I use the larger simple split shots. I really like the silicone lure though. Gotta get me some more of those and try them out.Never had a complaint against cheap lead shot, so that's a new one. Why would you need to close them by hand when you can easily press them together with a rock or other hard object?.
What I have in mine at the moment is Aqua-Pouch Plus. I also have a couple of roaster bags with water markings on them. I've never split an Aqua-Pouch and I like that they stand still and you can just drop in your tab. I've also added other faster acting purifying tabs, but kept the Katadyn in there for obvious reasons.As far as Ziplocs vs. Aloksak, the Aloksak wins every time when it comes to being tough, IMO. I have ripped way too many ziplocs in the bush. Never torn an Aloksak.
Yeah. In an E&E situation, most of the kit would be distributed about various pockets and what not anyway. Certainly the tools. With a suture you can stitch the key to the back of your trousers, and it's breakaway plastic when you need to get to it.The handcuff key is designed to be taken out of the kit and attached somewhere else. It's not meant to stay in the kit, the same way that a lot of the kit components are used to support other gear than you may have on you in an E&E situation. We did our best to design this kit to be as stand-alone as possible while staying compact but also be used with other components.
No. As I understand it, it's only a half dose of diamode in the pack. I would have liked a second 2mg tablet so that if necessary, I'd at least have a single first dosage.Diamode does come in the basic kit, as does Medi-lyte, aspirin, sun screen, DEET, Blistex, sting relief, triple antibiotic ointment bandages, etc.. You either overlooked the Diamode or someone took it from your kit before you got the kit.
Well worth buying if you don't already have these, particularily for the haemostatic gauze which I wouldn't be without.The advanced kit also includes the widgy bar, suture and Haemostatic gauze, etc.
No. I don't think I was clear in my explanation.You should not need a magnet warning.... I have flown with my kit and no ill effects...
Advanced kit is well worth the money and well thought out. You need to swap out the compass, even if it's to another plastic button, but having discussions like these is good. Too many survival forums are full of people who sit around watching BG and just like to talk about their gear. You guys are lucky in that most of the gear is US sourced and you can suppliment the meds quite easily. It's much harder to get stuff in the UK (with the exception of the Pyser compass which is a UK item I believe?), particularly individually wrapped meds, and simple things like widgys and the likes. I've had to import a lot of stuff from the US.Great thread guys. Think I will have to urchase the Advanced kit.
