I think the fact that it works better tip down means your finger was riding the lock bar when the clip was tip up and now you are resting your finger in the clip instead.
On mine, the actual threads were stripped. But it was only one of my screws. I knew right away because the screw came out after about a half of turn.
Has anyone noticed the clip screws ant long enough to grab metal on the g10 side? I tried to flip sides, and one of the screws wouldn't bite at all (was fine on the other, all-metal side). The other screw would barely bite metal before bottoming out, but not enough to really tighten it at all. It would seem the clip screws are about a 16th too short for the g10 side.
Roger that, I figured I'd could get longer screws from KAI. But I won't bother them. I'm a righty, was just trying to set the clip up lefty to see if it would carry OK that way. Trying to get the clip so it wouldn't be putting pressure on the lock bar. It still does unless I'm careful about how I hold it for opening. I guess it is kind of a good thing, though. Actually makes the lockup stronger, I guess.
Humm... good idea. What I think I've been doing is middle finger on the tip of the clip, ring finger in the inward curve, and pinky curled up by the end of the clip, along the side of it. But sometimes I get lazy or in a hurry and place fingers wrong. Then it gets sluggish.
I know this is going to sound ridiculous to most but I am thinking I may actually want to remove the flipper from my 0566. I have the spring removed and prefer using the thumb studs to deploy the blade. The only tool I have to work with is a dremel. Anyone know how difficult it may be to grind the flipper away??
