natchezz
- Jan 6, 2006
Since these are sharpened at 15* do you guys sharpen them on the 15* side of the sharpmaker?
How about the 20* side for a microbevel?
You can use either... The 15 dps setting will likely work for a while then you can switch to the 20 dps slots. Personally I do the 20 just because it's so fast hahaSince these are sharpened at 15* do you guys sharpen them on the 15* side of the sharpmaker?
The 2.5 is now my most carried and often carried knifeI haven’t put it down since the day I got it in the mail.
I'll be working on some more probably in about a month or 2 maxJoshREK Knives , any estimate of when you‘ll be making 2.5 Embers again? Thanks!
Hey Josh any chance you can be talked into doing some scale liners at that time?
Yeah I should be able to thenHey Josh any chance you can be talked into doing some scale liners at that time?
The Ember 2.5 pairs nicely with the iMamba!
starting a one off 3.5 that I'm gonna do an auction on soon... figured I'll post up some WIP shots here for everyone to follow along!
So I got some desert ironwood form Arizona Ironwood a while back and decided to use it for a bookmatched set of scales on this build.... I think some black and white liners will look nice with it! I used some Blade Pro epoxy between both liners and scales and let them set up overnight before drilling my holes.
Then I went ahead and prepped the blank flats (which is already heat treated and rough ground) by surface grinding and hand-rubbing up to 400 grit
Before glue up I had to make sure to finish the blade/forward side of the scales because you can't finish this section after it's permanently attached!
