I bought knife from seller via email out of this thread.
https://www.bladeforums.com/threads...-knife-phantom-steelworks-skinwalker.1553023/
Upon receiving the knife I email seller telling him something is wrong, action is too tight and there’s NO detent.
Here’s the email excerpt
“....I've handle a couple of them, this one is not functioning properly.
BLy
Sent from my iPad
On Feb 24, 2018, at 4:43 PM, Ken Leung <kenleung1995@hotmail.com> wrote:
From what I understand, Chris designed that model to be a quick self-defence knife. It's designed to have a light detent so you can shake it out if you need to.
About the action, I'm sorry but that knife is running on Teflon washers. That is the action you get on most Teflon. It's not going to drop shut as if it was running on ball bearings. Teflon tends to be stiffer and a bit sticky but stronger than bearings. It's actually why it has a lighter detent. The Teflon helps keep the blade in place. I've carried it a few times so I know from experience that it will not open in your pocket. If you want a different action, I don't know if you can convert that one to bearings but your best bet would be to contact Chris.”
Closer inspection shows the detent ball doesn’t fall into the hole milled in the blade to accept it, hence NO detent. Blade will fall out on a mild shake. To cover that defect the pivot is tightened, otherwise the blade will not stay shut in the handle.
He refused to accept return on this defective knife and I can’t claim PP FF.
He ask me to do PP FF and because of his stellar 200+ positive ratings, I didn’t hesitate, a perfect setup.
BLy
Sent from my iPad
