By default, you are required to post pics![]()
Yup. What Blues Bender said...let's see it.
Hey Shun dudes!
Does Rocky give you a little wrench for disassembly with those knives? As far as I know, only the Hizen and Higo can be disassembled under warranty.
Hey Sled. Great find! Thanks for the pics. Just gorgeous!
So the RYO-H won't be released until February.
They probably delayed production for a while because of this:
"We have originally produced the concealed clip system to eliminates the uncomfortable feeling of the "clip feel" when gripping the handle.
However, it turns out that a part of the mechanism of this "concealed clip system" conflicts with US patent Nos. 8,112,894 and 8,783,141.
We have been licensed to use these US patents after negotiations with Mr. Joseph Caswell, the US patent owner."
As long as you're a light user, i would go with the ZDP-189 over YXR7 if edge retention is your main concern.
If you do plan on doing any light impact cutting, go with the YXR7.
The ZDP-189 will chip.
Regardless, should the need arise, Rockstead will sharpen your knife for free.
They will charge you if the blade is chipped.
And being you're in Kyoto, you could hop on the Shinkansen and hand deliver it.![]()
Which Steel would you say is best against rust?
Again, go read page #5 as this was discussed already.
Neither is a good choice if corrosion resistance is a main priority of yours. YXR7 is a carbon steel but has a coating to help with corrosion. ZDP has 20% chromium, but 3% carbon, so even though it's considered a stainless steel, it is very susceptible to corrosion.
This ^^^ If I remember correctly, the metallurgy explanation is that because there's no other alloying elements beyond Chromium, most of the Chromium gets taken up in carbides and thus is not "free" Chromium, which provides corrosion resistance. So combine that with the high carbon levels and you have a "stainless" steel that definitely stains.
...ZDP is probably the least corrosion resistant of our stainless steels. The large amount of carbon eats up much of the chrome forming carbides and there is less than you'd think for corrosion resistance.
I carry ZDP often, but Colorado is a dry climate. Less corrosion resistance just means more attention. Generally "high performance" anything requires more attention.
sal
The DLC coating will protect the blade, but it should still be wiped down with something like tuff-glide. Apparently the DLC coating has "dimples" according to Rockstead, and make the blade susceptible to corrosion. I'd imagine the partially coated YXR7 blades require slightly more maintenance.
