.One thing we try is pattern welding steel. We ask Bruce Evans of the Bladeforums.com how we could get more patterns in the steel. He just smile and suggested something little stronger than what we been rolling! Ja Mon!
Cliff Stamp try to break Rosta-Frei Steel blade in test. Everytime he bend it the Rost-Frei just spring back like tall weed in the wind. He try to cut 1" hemp rope with this blade. He cut and cut and cut until his arm is sore. Finally after 1 million cuts Cliff Stamp give up. "This Rosta-Frei Steel is pretty good stuff," he say, "And it never seems to need sharpening probably due to the transverse grind on the lateral axis blah blah blah." That's pretty big compliment coming from Cliff!
On a serious note... Has anyone here REALLY tried this steel?
I found the elemental properties of RostaFrei steel. It's heat treated to 64 RC and consists of the following:
1.1% Carbon, 28% Chromium, 2% Manganese, 2.8% Nickel, 1.5% Molybdenum, 4.5% Tungsten, 59.3% Cobalt, and .8% Nitrogen. I was able to sample a small, razor-blade sized piece of RostaFrei from a confidential source and had it tested.
In terms of cutting performance, RostaFrei won't chip when batoning through rocks, and I used it to hack through the engine block of a '64 Chevy. It was still shaving sharp afterwards. Moreso, I've found that RostaFrei is impervious to the elements and can NOT rust. I discovered that when stuck in my left front pocket, the chemical composition of RostaFrei actually repels Mall Ninjas and forces them to leave a trail of urine behind. This is some wonderful stuff!!!
