chiral.grolim
Universal Kydex Sheath Extension
In my opinion transverse toughness does matter, ... getting back to S30V, the target was to have a stainless with the wear resistance of D2 and the toughness of, get this, A2. A2? Yep, because A2 was long known for being a tough steel. In fact in the wood working world the very best chisels and planer blades were made of A2, and not that long ago - 10-15 years. Why A2? Because when they used it for the purposes those blades are designed they held their edge longer than other steels you might think would hold any edge longer - like maybe D2. Why? Toughness, not "wear resistance". Because what killed those edges wasn't wear, it was micro-chipping, one of the things that kills knife edges, probably more than what we think of as "wear". I did some work with people in the serious woodworker world some years ago, when they were searching for a better steel for those tools. What they went to was CPM-3V, not CPM-10V. Why? Because what really matters is what works. ... When you look back on the numbers however, you'll see that lateral toughness correlates reasonable well with actual performance. You can't say 8 is better than 6, but you can probably say 10 is better than 4.
Due respect, you are talking about strength or "stability" as relates to fracture resistance - i.e. slow-loading of an edge that then chips-out - which is distinct from impact toughness (fast load, insufficient time for plastic deformation). The two do correlate, but again the relevance of transverse toughness vs. longitudinal toughness comes into play. In Landes work on "Edge Stability" he performs micro-loading of the edges to induce lateral stress and see which steels fracture out first (what you are talking about). His results show that above 15-dps it is difficult to distinguish between many steels because even large carbides are stabilized in the matrix.
When you load an edge, you are stressing it longitudinal until you induces sufficient fractures to allow propagation along the grain, whereupon it is transverse and propagates more easily, but getting there is the real challenge. If sufficient impact-stress is present to exceed the 28J limit of S30V, it is already sufficient to exceed the 10J limit, the latter is irrelevant. It could be 10 or 8 or 4 transverse, it doesn't matter because the stress was 28 and the effect is the same for all, i.e. failure. But A2 presents longitudinal toughness ~40J. 28J isn't enough to cause a fracture, the transverse toughness doesn't even come into play, again it's irrelevant.
What is the transverse toughness of A2? What about of any PM steel? Why would it matter?
As to wear-resistance being less important to wood-planer blades, Steve Elliot's work disagrees with that. In his testing, M2 steel (toughness ~20J like D2) performed above that of high-end A2 blades, and CPM-3V performed highest. The M2 and 3V blades showed the highest chip-resistance (again, this is slow-load strength/stability, not impact toughness) and the highest wear resistance which does indeed matter: http://bladetest.infillplane.com/html/summary_of_results.html
