Cliff Stamp
BANNED
- Oct 5, 1998
I'm saying that you also have to take Crucible's data into consideration. You would rather ignore it altogether as biased.
A bias doesn't mean you ignore the data, it just means you are aware it isn't population representative, it represents the behavior of a subset. It generally comes from a carefully culled subset where test data is selected based on selling points or the data is subjected to a systematic error such as someone who lives in a really dry enviroment has a biased viewpoint on the requirement of corrosion resistance.
Neither of us has provided actual material data to support our views, thus you are demonstrating as much "faith" as me by your own definition.
I have provided you with significant materials data, these are not issues simply on S30V but general principles of metallurgy.
I haven't seen independent test data to verify your scientific knife testing, so why should I have faith in it?
There is no issue of faith with any data regardless of the source. You examine the data and see if it supports the conclusions. You then see if the predictions made by the conclusions hold true. You also look to other sources for contraditions or validation. This is why it takes time for ideas to generally be accepted because you look for others to confirm the results, expand on it, refine it and show the limitations. Note for example Swaim's work on rec.knives was independently checked by Talmadge and then again I verified the work. None of us proceeded on a viewpoint of faith, you always have the focus of a skeptic.
My first S30V blades were hardened at 950F and in some brief of testing I found the steel was slightly tougher at that temperature than at 600F.
During secondary hardening there is a massive drop in both impact toughness, corrosion resistance and edge stability (ability to hold a fine polished edge). There is materials data on all of those and it is based on the fact that during secondary hardening in high chromium steels there is a significant precipitation of carbides (chromium rich) and these tend to form at grain boundries. This is fundamental behavior of such steels, you will find it in any materials reference on high chromium steels. This precipitation both embrittles the steel and of course reduces the free chromium and thus reduces corrosion resistance. I also reduces edge stability which was shown by Landes.
However in the steels which are tempered significantly higher the chromium won't form chromium rich carbides and the carbides that form won't do so in grain boundries and thus the embrittlement isn't a concern with 3V for example. But you will again lose a significant amount of corrosion resistance vs a low temper as the chroimum has still precipitated. Note this isn't even a property specific to stainless, carbide precipitation during tempering is what causes the 500F embrittlement in low alloy tool steels for example.
It is also why Landes recommends quenching after the temper to minimize any precipitation see his very involved method for hardening steels like 13C26 for example which has three cold/temper/quench cycles.
I've not examined those teeth microscopically, but I know they break off quickly and when they do the blade is dull. That is true of many steels with that edge, but for some reason it's worse with S30V. With a 15 or 6 micron edge, the steel is great at edge holding.
This depends on what and how you are cutting more so that the steel. S30V as well isn't optomized for a fine polish as the carbide volume is too high and there is too much chromium carbide, steels like 13C26 are designed for a high polish. S30V is optomized for holding a thicker/coarser edge. Landes work shows in detail how the carbide size and volume influences edge stability which is supported by a significant volume of measurement including many P/M steels from different manufacturers. Wilson has also used S30V extensively (and S90 and S60V) with a coarse finish and the edge holding is very high when slicing, much better than if the edge was polished and he found this as a general principle which is why he sharpens his hunting knives to a coarse finish. This general principle was studied in detail by Swaim and company on rec.knives many years ago. It is also mentioned in Lee's book on sharpening which predates Swaim's commentary. CATRA also claims to have been aware of it for some time and there is recent data published by FuriTech on the same.
-Cliff
