- Jul 5, 2007
from what i hear, s30v is awfully brittle, but then again variety is the spice of life, and these days if you want it, they probably make it if you look hard enough.
so then what is a good tough steel for medium to semi large blades (4"-6") for outdoor/survival? like for chopping wood, cutting metal, hammering, pounding, prying, etc that wont break and can stay strong and sharp?
S30V is a great steel. IMHO, the very best stainless available. It is not "brittle".
But it would not be my first choice for impact strength. That would be 3V.
Jerry Hossom used S30V in many large knives. Frankly I'm surprised no-one mentioned it...*shrug*
52100 (SR-101)
O1
A2
1095
i'm at the benchmade knife wizard page and went to lookup some fixed blades made of that steel and they don't have any of that steel for selection... http://www.benchmade.com/products/knife_wizard.aspx so as the newbie i am i am having a hard time believing any of the above mentioned steels are good for what i need.
First there is no guarantee that having it softer actually makes it tougher. The toughness dependance on hardness is usually highly nonlinear.
Second, the reason they have stated in the past for the lower hardness on S30V and A2 is ease of field sharpening on rocks and such. This is nonsense by the way.
-Cliff
If S30V were brittle, why would I and a whole lot of other knifemakers use it?
It was specifically developed as a stainless version of CPM-3V (a very tough steel).
Part of the problem here is that once something like "S30V is brittle" gets established, and it has, it becomes imbedded in the online spec sheet for that steel...
More and more companies are using [S30V] too. Would you call their investment foolish?
Because it sells. A statement is also not strengthened by repetition or numbers.
That is absurd, if that was the case you would look at 12C27M or similar. Similar for non-stainless, if you want a tough steel then you reduce the carbon and carbide content to bare minima.
The "design" goals of S30V were "a stainless tool steel as tough as A2 and as wear resistant as D2". A2 is a tough steel; D2 has excellent wear resistance; combining those virtues makes a very good steel, especially a stainless steel. ...Not many steels can compare with CPM-3V in terms of toughness under any conditions.
BTW, if tolerating being hammered through an 8d common nail isn't sufficiently tough for your needs don't buy 154CM either.
