Gator, how could I misquote Cliff when I used a cut and paste of what he said?
Because what you CONCLUDED was incorrect.
The Buck Solution review from his own website clearly states the blade was used and chipped when received, there is no mention of a carpenter or carpentry tasks, and the blade ultimately broke after being abused in various ways and by driving it into a piece of spruce, standing on it, then hitting it with a hammer - not common carpentry tasks here in GA anyway.
The relevant section :
"On harder woods there were durability issues. The solution was chopped into 5/8" thick birch, and torqued to the side which left a huge piece of the edge in the wood. This was repeated breaking out another large pice. The penetration into the wood was fairly low, as the handle ergonomic issues prevented serious swings. For similar reasoning it wasn't heavy torque, just wrist rotation. "
The primary grind was destroyed at this stage by very light work which is common in carpenter at the framing level (taking apart existing work for reconstruction). Here is a reference picture :
Those huge circular pieces are what came out in the light wood working. The fact that the edge was chipped initiall is completely not relevant. It was also clearly noted in the review. I thought these were in the review. THey are in the thread here, I will update the review on the cite later with a few pictures.
As for the qualitative work you mentioned. As I noted many times, the reviews consist of quantitative and qualitative work. Of course you need to look at the CONCLUSIONS which are drawn to judge the tests. I have done nail cutting myself and concluded it is useless because I can do it with any knife if I am careful enough. You on the other hand imply that it is some sort of meaningful test which is nothing but HYPE.
I am the one pointing out the limits of what I have done. You are the only spreading conclusions with no FACTUAL support which contradicts MEASURED FACTS by many independent sources.
Are there really photomicrographs which show 12C27M and 1050 have the same microstructure?
Well if you looked at the C/Cr diagram that Verhoeven noted you would see the carbon content in solution is the same (tolerances) and thus the austenite will behave that way in regards to hardening (with the expected effects of Cr in preventing the diffusion forming, i.e. pearlite).
Of course it depends on how they were heat treated. You can leave as much of the Chromium carbide in 12C27M in the austenite as you want. But ideally it is designed to run with almost none as it will lie almost on the saturation line and thus have the hardness you would expect with the given carbon in solution.
Anyway like I said, read Landes book or just call him. I have, he will actually educate you if you want.
Does the laboratory model (Landes or the inormal one shown on Messerforum) represent how steels actually behave in knives?
Yes, that was why it was developed because the CATRA tests do not. Again if you read the book or called him you would know this already. What is your resistance to learning?
If they support that 420hc has better edge retention than S30V, I don't believe the models accurately reflect how steel knife edges are shaped and work.
Of course because the experiment does not support your theory. The reality is you do not understand what they did or why it is superior because you do not understand what edge stability means or what properties influence it and what it means in regards to use.
The guys on the forums did physical cutting on rope BY HAND. It was not artifical in any way. What they saw was DIRECTLY in agreement with what Landes measured and is the same thing Johnston saw when 1095 easily had better edge retention than ATS-34 in his knives when tested by working people, tradesmen, cowboys etc. .
Let me point out that contestants in the Professional Cutting Competition use high carbon (~1% C) steels. CPM-M4 (1.4% C) blades often win, as do blades in O1 (0.9% C).
How much of the carbon in 52100 is in the austenite, I will give you a hint, it is the same as a stainless steel I mentioned which rhymes with 12C27M. Here again you show a complete ignorance of understand of even basic issues of heat treatment, judging the performance of a steel by the level of carbon and ignoring the amount of carbon in the austenite and in the carbides. This is what is critical to performance as it will determine the wear resistance and the responce to quenching.
In REALITY, both of them have the same amount of dissolved carbon (0.52 for 12C27, and 0.055 for 52100 at the ideal austenite soak temperatures), and the same resulting hardness (which you would expect as it is mainly correlated to this - FACTS again). Do you really want to continue to argue one has a really weak edge prone to deformation and you would be ashamed to make a knife from it and the other is just extremely excellent? You want to cite ANY FACTS to support that claim at all.
How about 1050-1065 and similar steels? HOw are they going to be so excellent in regards to edge strength when 12C27M is so poor because it only has 0.52% dissolved carbon? Is it because the carbon steels are american?
-Cliff
