I think you’re onto something with that denim
I agree. Visually appealing and unique.I think you’re onto something with that denim
Agreed. The good thing is that it all gets easier with practice.It's actually not that hard at all.
I think if I can do this, then anyone can. All you need are a few basic tools and some free time. The hardest part is simply getting the back pin out cleanly. The rest is easy street. It only requires time.
I think a 1/16” or 2.0mm punch would help you a lot if you’re going to do much more modding and swapping.I used:
a small cheap file
a small cheap hacksaw
a few sheets of sandpaper in various grits from p120 to p3000
a bench vise
a small 5 ounce ball peen hammer
To fully drive out the stock pin I had to flatten the end of a small nail and drive it through the pivot slot to chase the pin out.
Cool!! Nice work!Well, it's done. Could stand more finish work, and there's some at least one big screw up. But it's together, it works, and if I keep going I'm just going to grow resentful of the project.
Newfound respect for anyone tackling these on the regular. Maybe these German Army knives just have RIDICULOUS backsprings, coupled with crappy, soft aluminum that deforms every time you sneeze, but assembling this thing really spiked my blood pressure.
@The Aflac Duck will be pleasedFinished up another colab with Chip @WValtakis I can’t say enough how awesome his engraving work is!!
Well, great job getting it done! I really like the look.assembling this thing really spiked my blood pressure.
Thanks. And absolutely.Well, great job getting it done! I really like the look.
But you’ve got me thinking I should start a thread on some of my assembly techniques…none of which use a jig, but leverage to bend the backspring and seat the tools within the layer. Simple, but pics and explanations would help, I think.
As these Al2O3 bits wear down, you might nick your bushings. I like to use an auto center punch to put a dimple in the center of the rivet. Then I put a center drill in a hand feed chuck. The large knurled disc doesn’t turn while the small chuck is being turned in a large chuck in the drill press. The small spindle has about 1” of travel inside the large spindle. The knife is held in a vise. If you open the blade(s) part way, they help keep the rivet from turning.View attachment 1906263I'm thinking of putting either a DeWalt DWA4974 hex bit or DeWalt DWA4975 hex bit into a regular hand held 1/4" hex bit screwdriver and using it to sand off the rivets on a 91mm SAK while preserving the bushings. These are aluminum oxide grinding bits so they should work on brass.
Will this work or are the tips of these two grinding bits too large? The point is to do this by hand. I want to avoid using a power drill.
I'll take that as a "yes", then.As these Al2O3 bits wear down, you might nick your bushings.
You could turn your screwdriver into a bow drill and start a fire.I'll take that as a "yes", then.Either of them could be small enough to work.
I don't plan on customizing a lot of SAKs, so I doubt I will use the bit enough to wear the tip down to make it too fat. If it actually does wear down that fast on soft brass, then it should be no problem to quickly reprofile the tip and resume using it.
These bits are relatively cheap. If they work, it would give people on a budget something they could use without spending too much. Most people already have some kind of screwdriver that takes hex bits.
My guess is these will serve you better. I don’t have much experience using grinding bits on soft metals, but I think there’s a reason for that. Might work ok if the tip is small enough, but I think that will also be an issue.I also picked up an inexpensive set of 1/4 hex drill bits in a range of sizes starting at 1/16th of an inch and increasing from there.
