Fryed to a really dark colour Pear wood
And some lighter fryed Olive wood
I really like how that looks.Coaled Oak
It’s basically artificially produced Bog OakI really like how that looks.![]()
Beautiful work as always my friend!Natural Oak Spartan & Coaled Oak Sportsman
85mm with file vs 91mm with small blade
About the same thickness
I have a sneaking suspicion that we will be seeing that one from time to time on the forumAnother Micarta/Ti Compact Tinker
This is a mock-up of how to build a SAK with a back Phillips and a corkscrew at the same time. It has to be at least 3 layers because the Phillips driver protrudes into the layer next to it. With this configuration, the Phillips is able to sit all the way down so it's nice and flat with the profile of the SAK.
The center layer has no back tool. The missing back tool makes extra room for the Phillips driver to fit. The back tool is what tensions the spring for that layer, so you have to put something there to use as a spacer. I've used a squished brass bushing as a temporary stand-in for this mock-up. For a final build, you could use the pivot side of a back tool and cut the rest of the tool off.
I think what I'm going to do with this is use it to make a 5 layer Ranger where the dolphin screwdriver and the parcel hook are replaced by the Phillips driver, so that it's a Ranger with a corkscrew and a back Phillips together at the same time. A Ranger with a Phillips instead of the corkscrew is called a Master Craftsman, so I think it would make sense to combine the two names by calling it a Master Ranger if it has both a corkscrew and a Phillips on the back side at the same time.
I think the key is in the application. I would advise to simply avoid applying glue around the bushings/pivots or anywhere too close to them, especially if the glue is capable of bonding metal. It should be more than enough to selectively put glue on the surface of the sideplates where it can make contact with the underside of the scales. That should work just fine unless the scales are hollow underneath. Most 3rd party aftermarket SAK scales aren't hollow.I once reglued rubber scales on non-sak and the damn glue worked itself through the pivots and almost jammed up the entire knife.
Thanks, makes complete sense! I have seen vids where they instruct putting glue to the pin holes but that always seemed weird to me. Now I have to see if I can justify spending on scales that cost more than the knife itself…I think the key is in the application. I would advise to simply avoid applying glue around the bushings/pivots or anywhere too close to them, especially if the glue is capable of bonding metal. It should be more than enough to selectively put glue on the surface of the sideplates where it can make contact with the underside of the scales. That should work just fine unless the scales are hollow underneath. Most 3rd party aftermarket SAK scales aren't hollow.
You also don't need to spread the glue. Try making little dots or small lines with the glue, and give it plenty of room to spread by itself when it gets squished by the scale.
Yeah I definitely wouldn't do that!I have seen vids where they instruct putting glue to the pin holes but that always seemed weird to me.
SwissBianco sells 91mm anodized custom alox scales for around 30 bucks a set, I think? That's way less expensive than a lot of the other options out there.Now I have to see if I can justify spending on scales that cost more than the knife itself…
