Here is an example of how you might go about finding creative solutions for including scale tools in a 74mm custom alox SAK with no scale tool slots. This is based on the Alox MoneyChamp build that I previously posted in this thread.
From left to right: 3x1mm neodymium magnet, straight pin, modified Victorinox tweezers, Leatherman eyeglass screwdriver bit.
The plastic nub on the back of the tweezers has been thinned down with a file. The ends of the tweezer arms were cut off to reduce the the overall length of the tweezers. The tweezer tips have also been angled for greater precision.
The eyeglass screwdriver bit can be wedged between the backsprings of one of the thin layers. The main body of the SAK can then be used as a screwdriver handle to drive the bit.
Using a thin layer to hold the bit is important because a thick layer will be too wide to hold the bit snugly enough, which causes the bit to wobble from side to side. A thin layer will hold the bit solidly so that it has no wobble.
The small magnet is used to hold the bit and the straight pin in the parcel hook slot.
The parcel hook closes down over the tools. The tools are just the right size to fit under the parcel hook without interfering with its ability to close down all the way. The magnet does not get stuck to the parcel hook. It does not interfere with the parcel hook opening or closing.
The magnet does stick out a little bit into the scissors layer, but its not a problem. This probably happens because the scissors backspring is so thick that it attracts the magnet very strongly.
The position of the magnet still allows the scissors to also be able to close down all the way without any trouble. The magnet does not cause any issues. It does not get stuck on the scissors. It does not interfere with the scissors opening or closing.
The tweezers are stored securely under the combo Phillips tool. The tweezers are modified to be exactly the right dimensions so that they do not stop the combo tool from being able to close down all the way. This took some trial and error to figure out. You can check if the tweezers are causing interference by pressing down on the spine of the combo tool. If the tool feels springy, then the tweezers are preventing it from closing all the way down. If there is no springiness, then the tweezers are not in the way.
