- May 29, 2004
"Heavy is good, Weight is sign of reliability. If it doesn't work, you can always hit him with it" Boris the bullet dodger (Snatch)6lbs of awesome![]()
There’s a joke in here somewhere.I wouldn’t worry about it. The ruler is a lightly stressed tool.
I also did the hidden pin for the springs. Why did Victorinox do that back in the day?
You are probably right about The Shield and the over all design. From what I have read, they are very proud of The Shield logoMy suspicion/theory is that the 4th pin made the scale too ‘crowded’ once the shield inlay was made standard. The somewhat rare 4-pin with shields, have the two very close together.
like this:
After these were made, the shields generally stayed in the same place and the 4th pin was hidden on most models going forward. My feeling is that it’s also somewhat easier to do, and arguably cheaper. Until the bushings were used, the 4th pin was typically just flush cut. Two fewer holes to cut through the scales and two fewer rivet heads to finish. Seems very Victorinox to me.
Smart use of acetone. Nicely done.I put a drop of acetone there and waited a few seconds and then poked the shield thru that small hole. I used a dull needle. After putting another drop of acetone and some more poking, the shield fell out in perfect condition.
I have chemically pure gasoline and pure acetone in my cabinet for different cleaning jobs, my wife have acetone with oil for nail polish removal. I don´t know how fast Isopropyl vaporizes, but acetone is pretty quick, wich is kind of good in this caseSmart use of acetone. Nicely done.
Isopropyl (a.k.a. "rubbing alcohol") disolves the scales too, so may also work for this method of shield removal. Acetone is used as a nail polish remover, so it's pretty common to have some on hand, but isopropyl is even more common since it is used for sterilizing cuts and scrapes. It comes in different concentrations, with the consumer grade usually ranging from 70-90%. It would be interesting to see if the concentration impacts its effectiveness in freeing the shield.
how on earth did you cut the inlay for that shield to go in?this is how the first scale looked after it took a swim in acetone
And this is the *first try to attach the shield with epoxi.
I first drilled a 1mm hole in the scale, just about 1mm deep. Then I put a drop of epoxi in it. I then had the shield on a piece of tape and put glue on it with a needle under a magnifying glass. Once attached I removed the tape and cleaned off the glue that spread outside the shield with a soft cloth with water and soap. It looked good, but I was not sure that small amount of epoxi would be "safe", so I filled the shield with epoxi. Now it looks like the shield is glass filled
On the *next try I want to make a 12mm round epoxi cover of the shield, I just need to make a good enough template before I give it a try![]()
Isopropyl is actually pretty well known for its rapid evaporation. I would be surprised if it wasn't faster than acetone, depending on the concentration. I'm pretty sure isopropyl is also less toxic. It's certainly a lot less odious.I don´t know how fast Isopropyl vaporizes, but acetone is pretty quick, wich is kind of good in this case![]()
That´s it, I didn´t. I realized I will not be able to make a cut out that will meet my OCD for perfect fit, so it´s sits on top of the scale. Glued on with epoxi and then filled with epoxi. The shield is super thin, only 0.15mm, so you can barely feel it when glued on (but you canhow on earth did you cut the inlay for that shield to go in?
The odious is what makes it funIsopropyl is actually pretty well known for its rapid evaporation. I would be surprised if it wasn't faster than acetone, depending on the concentration. I'm pretty sure isopropyl is also less toxic. It's certainly a lot less odious.
In order to order replacement screws, you need to know the thread diameter, thread pitch, thread length, material, head style, and tool style. I doubt that the screws were filed to length after assembly. It messes up the scales. There are some assembly videos on YouTube.Hello everyone. I usually lurk here and don't post mods. I have a question though. I have this little Executive that I purchased from a well known SAK modder on Instagram. I had a screw that kept backing out on this knife. I had the bright idea to unscrew it and add some Loctite to it and screw it back in. BAD idea ! The knife basically exploded when I backed the screw out. I therefore had to disassemble it to get the springs back where they belong. I have contacted the maker, but no response yet and I'm pretty bummed out that I destroyed one of my favorite SAKs. Question is, where is the best place to purchase replacement screws that are longer than the ones in the knife in order to pin it all back together again and screw the back side scale back on? Apparently. the screws were cut and filed after it got screwed together, because reinstalling the old ones and trying to screw it together doesn't work due to the spring tensions.. Any help is appreciated.
Gerald
Usually with the smaller SAK customs they will tap their own threads in the holes for one scale and then screw the pivots directly into the scale itself.Isn’t it two screws and a tube that holds it together?
