Bark River uses 12C27
stainless Opinels
*slaps forehead*
stainless Opinels
IIRC, the carbon Opinels are 1075, so I don't know why either would be sharper than the other.![]()
19C27 isn't blankable, so they would never switch to 19C27. They're already making the switch to 14C28N. Also, 14C28N is more corrosion resistant than 13C26 while 19C27 has less corrosion resistance than both. For mass produced knives sold at places like Wal-Mart, high corrosion resistance is a must.I've seen folks ask Kershaw to "upgrade" from 13C26 to 19C27, so who knows?
I'm very, very impressed with these Swedish strip steels and can't wait to try more knives made from them.
I'm sorry I'm not Jerker, but the Sandvik grades are easy to rank in edge stability because the more carbon it has the greater the carbide size and volume, with most of them having very tiny carbides, but 19C27 has a few larger ones. Carbide size and volume are the main things controlling edge stability. When carbides in the steels have a small variation in size, and the average size is all that changes from steel to steel, they are easy to compare such as 12C27 vs. CPM-154, where the average carbide size of 12C27 is uner 1 micron, and CPM-154 is around 4-6 microns on average; of course the 12C27 has greater toughness and edge stability, and the CPM-154 will have greater wear resistance due to the greater volume of carbides. Where the difficulty comes in is where a steel has a smaller volume of carbides but some are larger, such as 19C27, which has around half of the volume of carbides as CPM-154, and the average size is smaller, but there are some larger carbides. In general in reading Roman's book it seems that the smaller volume of carbides wins, though I assume this isn't always the case, as according to Landes CPM-154 has relatively poor edge stability (or at least RWL-34 does), though of course the edge stability and toughness is greater than plain 154CM or ATS-34.Jerker,
Can you explain how you came up with your ratings on edge stability? I have looked into this and asked about this steel characteristic but have not got any detailed information on how it is determined or tested beyond Mr. Landes' descriptions provided here a while back (he described a test that applied a lateral load on the knife edge, but didn't explain how the results are measured or observed). I'd be interested to hear how you have rated this, or any insight you have on it.
Thanks!
