- Dec 21, 2006
Luong, your reply to the VC volume % in 10V was not a reply at all. Elmax and chromium carbides? Whatever man.
I guessed the curvature by how much light reflected back from single light source.
^ Outstanding follow-through with a well conducted test, Steel_Drake!
I am convinced with your evidence of 1 (Spyderco Maxamet Mule) which supported your assertion. I am looking forward for one more evidence - HeavyHanded's guided tests with 10V... Then I will try to replicate at my end using various sharpening medias & styles.
After that, I would like to see at least a few evidences that average sharpeners can actually produce equivalent edges on high vc steels regardless of abrasive.
So, with your finding, maybe it's practical - for me - to toss/dope 1500grit SiC onto a Spyderco M stone to speed up the abrading and finished up with fractured grit slurry. Most people (including me) would be happy with newsprint slicing edge. I don't care much for a couple dps convex due to slurry/mud as long as edge is less than 18dps.
A potential problem I see with sharpeners with less skills while using non-diamond/cbn grit smaller than 12um, is that in searching for faster cutting speed, they might use excessive pressure, end up with poor to bad results.
^ you wrote good disclaimer. If people asking you to teach them how to sharpen a high vc steels, would you recommend/teach them your approach or diamond/cbn? Or which one would produces higher success rate?
Won't the SiC wear the Spyderco M since it is made of aluminum oxide?
In terms of coming up with a practical approach to quickly sharpen high hardness, high VC steels the first questions should probably be what kind of apex grit do you normally use? Are you ok with using microbevels or prefer not to use them?
This is a very good point. I've always preferred to use very low force when I sharpen (that is a big part of why I prefer extremely weak bonded waterstones). The Spyderco benchstones in particular are well known for producing bad results even on simple steels when used too much force.
That would depend on several factors: How experienced are they at sharpening? How coarse or fine an apex finish they typically use? Do they use a burr based sharpening approach? Are they willing to learn a three step/burr minimization approach? What sharpening equipment do they have?
In general terms, for people who prefer to stick to a burr based sharpening approach and prefer to run relatively coarse apex finishes I would probably recommend diamond plates as the fastest option. This is also what I would recommend to novices since I think its much easier to start by learning a burr based approach and to shear off a burr using high angle passes rather than trying to start by learning a burr minimization sharpening approach.
I also probably wouldn't recommend using Spyderco stones for anything more that creating and touching up microbevels on these types of steels. Used for microbevels, their slow cutting speed becomes irrelevant since you're only doing 5-10 passes per side.
My advice would be different for anyone comfortable using a three step/burr minimization approach (for those not familiar, the three step approach is to cut off the old apex by drawing the knife into a sharpening stone until the apex visibly reflects light from a directed light source, shape the edge bevel until light from a directed light source no longer visibly reflects from the apex while trying NOT to raise a burr, then increase the angle and set the apex by creating a microbevel with ~5-10 passes per side), since in this case very muddy waterstones are preferred for shaping the edge bevel for their burr minimization benefits. For anyone (like myself) who uses this approach, there is no reason not to use waterstones on these types of steels since very muddy waterstones appear to work fine and any apex rounding that occurs is irrelevant since a microbevel will subsequently be applied.
My own approach is chosen based on being comfortable using a three step/burr minimizaton approach and preferring relatively fine apex finishes. Basically, I want the fastest way to get a ~4000 grit apex finish that will easily do crossgrain pushcuts on newsprint, and which I will be able to keep touched up for some time between full sharpenings. For me, I would use an SPS-II 240 to remove the previous microbevel, SPS-II 1000 to shape the edge bevel until the apex no longer reflected light from a directed light source, and then set an apex microbevel at an at least slightly higher angle using a DMT EEF or Spyderco M (or a coarse particulate abrasive loaded strop, but that's a topic for another thread). This approach will get me from cutting off the previous apex into a stone to doing crossgrain pushcuts on newsprint again in ~10 minutes.
Edit to add: I can't believe how flexible this thing is at 68 RC.
I've been playing with the Naniwa diamond stones.
These are the 800 and 3000 grits.
It's an excellent combination and leaves a great finish much higher then the grit rating.
Extremely slow dishing and wearing, may take years.
Disadvantage is that these are slow stones, they also load up.
Comes with a cleaner stone that is made out of the Naniwa traditional 220 stone but in nagura form.
Also very very expensive, $150 to $170 per stone, yikes
But I've really been enjoying the results, I'll share more information as I use them.
Sharpened zdp-189 on a sharpmaker using diamond->medium->fine->ultrafine. No problem doing it, just had to be very patient.
Won't the SiC wear the Spyderco M since it is made of aluminum oxide? ...
...I've been playing with the Naniwa diamond stones...
Well, I did have to put a handle on Luong's 10v blank to work well with the clamp - it could do it, but being in and out of two clamps and repeat positioning fairly important I went ahead and fabbed one real quick.. Functional if a bit matronly, not bad for a piece of hickory and a few aluminum rivets.
I would like to add to this if I can.
I posted earlier (#171) that i wanted to remove those scratch path to microchip marks if I could.
I sprung for a new stone 1500 grit diamond for my wicked edge. https://goo.gl/photos/NAJaM3FhMJEJ1fzS8
...Results is no micro chips and no scratch path,and one very sharp knife.
This is all at 15deg/side.
I would love to contribute to this wonderfull crystal weaving method.
I will do a test but I need to plan it a little.
I love the knife so much I am cringing at that blade damage,need time to get comfortable with it.
The knife is a lot different now than when I got it.I have refined the heck out of it to a fillet-paring knife and I really like it.
It is tuned for ultimate blade control in soft tissue and skinning.The feedback from carbon fiber handle to blade is perfect and
the blade is nearing a mirror finish.(hard to achieve after hardening to hrc68)
Anyhoo good news is I have gotten photo through the microscope and will post revelant ones here.
Jay
I'll give you guys three guesses on what I'm about to say, though you probably won't need them.
There is an obvious tool choice for this application that is being overlooked. Sigma Power Select II waterstones are made from silicon carbide with very little binder, and should have no trouble cutting any steel regardless of hardness or wear resistance.
Exhibit A:
[video=youtube;Tsj1U2bx-L8]http://www.youtube.com/watch?v=Tsj1U2bx-L8[/video]
Considering I managed to successfully apex a ceramic knife on an SPS-II 1000, I don't see why it would have trouble 10v.
I finally got a half decent photo,should be good enough to show the scale of my microscope on highest power.
Excuse the external links only way l know how to show hi-resolution photos.
scale
https://goo.gl/photos/B6H37cnbRpgH9Kk97
scale and blade
https://goo.gl/photos/z58rwQaSLWNKfK9k7
