Bluntcut,
I'm aware that VC is harder than SiC, however I was under the impression that a highly friable SiC benchstone should expose fresh abrasive quickly enough in use to continue cutting effectively, without the problem of quickly wearing out like SiC belts appear to.
Also, I'm not sure if I'm understanding you correctly, but to clarify, are you saying that a steel with a high vanadium carbide volume such as 10V is harder to grind than a ceramic knife? If so, would you happen to know any reasonably priced commercially available knives made with a steel with a high enough carbide volume that I could buy one and try sharpening it on my SiC waterstones? Would a Spyderco Manix LW in s110v have enough vanadium to test this? Or would I need a knife in 10V specifically?
Worst case scenario, assuming your prices are reasonable, I'd be willing to buy one of your customs in 10V just for the purpose of testing out which of my sharpening stones can successfully sharpen it in a reasonable time frame, and to make a video of the results. I've often found that with sharpening knowledge there is no alternative for simply trying something yourself to see what will happen.
