Bending over all the time when you work is tough... limits the time I can stand to work.
Hmmmmm. I put the 4" drive wheel on mine with the VFD at 2x speed. Did you calculate out the belts speed to decide on the 6" drive wheel? I'm by no means an expert, just thought the 4" drive wheel was standard with the GIB?
Are you getting a VFD? And which motor?
every house has a double bar power source that your breakers run off of, each side is 110 V AC. the dryer gets 220 by pulling from both sides. usually there will be two diff breakers for the garage find out which outlet runs off of which breaker by pluging everything in and shutting off the breaker you think it is and see what turns off. make sure that this power source does not run to the garage door! when you pin point the outlet take the nuetral from that breaker take another breaker put it right next to the original breaker and hook the nuetral wire up to that breaker this will give you 220 to that outlet. i am an electrician so if you need any help with this let me know and i can put up picture directions for you. this will get ride of the extention cord problem it is also easy to switch back.
Are you suggesting to run 220 without a wiring upgrade? I'm not an electrician but that sounds dangerous. All of my 220 ciruits have dedicated 220type double breakers. Aside from my dryer which is on double post 40amp 120 breakers.
If I was going to set myself with 220V I'd definitely have an electrician do it to code, just like I did when I had the 20A circuit pulled. I don't want to run afoul of inspectors when it comes time to sell this house. I know I could do it myself... but I won't.
