Show the factory knives you've customized ... part 2
cpirtle, i just got my spydy police and i wanna make it MINE!!!
what do you suggest? theres not a lot of room to play becausr the blades so big, handles so small and thin
im using the ss plain edge
Elk antler Seax by Bob stine, I did the etching, gilding, handle carvinng and pinwork.
attachment.php
attachment.php
attachment.php
Keith
Himalayan Imports Khukuri, 21" Gelbu Special. Blued in the three suns pattern.
attachment.php
Arms & Armor Shifford Viking sword, blued with runic inscription
attachment.php
attachment.php
Kris Cutlery baselard, etch and copper plating detail.
attachment.php
Aftermkt mods is what I do.
Keith
anyone have any advice on what i can to do customize my knife?
(stainless spydie police plain edge)
Hi Aaron,
You may have a hard time with that one because it does not have a removeable blade. Any grinding you do to the handle is going to shoot debris into the pivot and chew up the notoriously thin Spyderco washers.
I basically took the blade off of mine and formed it on a drill press spinning a 4" sanding drum and then contoured the rest and did the finish work by hand.
If you were going to try something I would stuff as muchstuff in behind the open blade as possible then tape it up with cardboard and duct tape to seal it well. This would minimize the amount of crap that would get into the pivot.
Then blow the whole thing out with a compressor or canned air before and after removing the wrapping.
Good luck :)
Very old, very abused Recon Tanto that I redid. Sorry for the crappy picture -- (especially since I shoot photography.)
cpirtle, Outstanding thread, So do you want to take an order to replace my inserts on a Socom with scale inserts like you did above?? :D
LOL... get in line behind my wife :)
You'd have to wait until I finished a pair of these Arts & Crafts style chairs for the den we just remodeled, and an island for the kitchen we just remodeled along with a laundry list of end tables, cabinets and lamps....
So it may be a few years before I can take any orders ;)
Glad you like the thread though - I really do have fun customizing knives in my spare time though.
attachment.php
CP,
Are you done with my matched set of 7 Ironwod Adirondak chairs yet?
:D
OK, how about alittle instruction on how you did it. Where did you get the material?? How did you cut it to shape?? Did you have to get extended screws?? I have a Socom I am working on refinishing the blade and was going to go with RaySkin Inserts, but I like what you have done ALLOT!!
dammit Ebbtide, I thought you ordered cocobolo! :)
TBG, I used 1/8" thick ivory Micarta. Carefully peel out the rubber inserts and use them as a pattern. Cut them out with a scroll saw to the rough shape then use files to shape them so they pop into the milled out recess nice and tight. You may be tempted to use a Dremel here but I would stick with the files as they remove a lot less material and will give you a better fit.
Once you have them all shaped chamfer the edges with a file and sand them, I usually start at 100 grit and go to 250 grit - then finish off with a green scotch brite.
Pop the Micarta back into the handle and use the proper drill bit for your tap to drill through the Micarta and the aluminum scale. Pop out the insert and tap the hole. Now bore out the hole in the insert to fit your button head screw and counter sink it. Touch up the Micarta with your green Scotch brite and screw them in place.
Now on the back side of the scale use a dremel or bench grinder to grind the excess length off of the screws so they're flush.
I got the Micarta from a combination of Texas Knife Makers Supply and Koval's - I have a ton of it so I'm not sure which place that particular piece came from.
Also note, 1/8" stock was a good fit for the SOCOM but with the CQD I had to this the Micarta down to a little less than 3/16".
Good luck!!
PS - I would only try using Micarta if you're not familiar with this stuff. G-10 and Carbon Fiber are much harder to work with. All of them are bad to inhale so wear a respirator too ;)
:eek: Maybe I will just wait until you have your wifes projects caught up and bride you to do it!! :) Thanks for all the info
Hello.This has been fun to watch. Great stuff all the way around. Here's a Shark I spiffed up a little. Rich
OK, let's try this out..
By the way..LOVE that Dieter II !
//http://www.knifeforums.com/ubbthreads/files/164781-AMPH%201.JPG
OK, I'll play. Here is a pic of a Swamp Rat Battle Rat that had the coating removed and the grind thinned down a bit
attachment.php
Fallkniven F1 with mortised Brazilian Rosewood handle
attachment.php
Here's another one... I found some time to sneak it in :)
SERE 2000, Desert Tan G-10 with Black Micarta dots and thumb ramp checkering...
attachment.php
attachment.php
This one has been a project and a test mule for all kinds of stuff :
Emerson Commander...when I bought it the blade had already been hand rubbed out...I took a bit of extra time to rub it more and clean up a few spots , then I jeweled the liners , made a 3/4 length backspacer out of 6061 Aluminum , and finally yesterday , my bes bud Kyle got his anodizer up and running and we anoodized the scales a spackle type finish of a gold and purple/blue .
What da ya think ??
oh yeah and special thanks to Al for sending down the Skull Clip !
Hard to capture the anodized liners without good lighting.
