Haloblue, I spoke to Rod about a month or two ago. He said because of the economy he has had a lot of cancellations. So, you may be able to have a Skookum a lot faster then you think.
Nice! Thanks for the info. I could live with that.
Is the rear lanyard hole like that because the rear rivet holds the butt plate on? I am guessing that's the case.
It's a beautiful knife. I will say that I prefer to have some kind of integral contour or ramp to keep my hand from possibly slipping onto the blade. Otherwise the design is fantastic.
Is there a reason that Hiwa's blade looks shorter then pict's? Can you order this knife with a different length blade? Does anyone have a picture of the shearing hole as well? I dont believe I have ever seen a picture of it.
Nice J, I think you will love the one from Brain, as well as the Skookum. Give a me a couple weeks to play with my Terassur, then I can send it to you for a couple weeks. Just be easy on her.
Mine is a2 natural linen without butt plate. Rescue Riley is in possession of Will's SBT. It is a2 as well. I compared the 2 together on Wednesday. The handle on Wills ia a lil wider than mine, which I like alot better. I will probably order another from Rod as well. I will however ask him for a wider handle. I would opt for 01 instead of a2, but that is me.
Over all it is a great knife, I might use mine more if the handle was a lil wider..
Also, I have no c lue why the lanyard hole is inside the last pin and not at the end of the handle. Makes no sence to me... That would be my biggest complaint.
