I don't think I know anyone personally that knows the definition of that word. I can guess though...Mainly just having fun, too hot to go outside 94 @ 10a...
I know the definition
So the lock bar has the bump and not the blade.?
It mightafter reading Jeffs explanation I will be removing the hump on mine only cause I don't care for it and it's an easy fix
very nice Knife even with the hump
Opening the blade half way is the way to go. The hump is just a cosmetic flaw and no way will hamper the way the knife performs. I think it's just one less step to keep costs down and that's fine by meAt first I thought the reason for not grinding the hump off rhymed with "hazy", if you know what I mean.
But your side by side photo shows how it's a combination of things at work. I know with a very high degree of certainty that the 110 blades and lock bar are both blanked with that hump in them for the reason stated earlier. The early Bucklites like the one on the left in your picture are clearly ground on the spine. The texture left on the handle matches both the blade spine and the lock bar, and you can clearly see where the grinding stops as it curves over the front of the knife.
The new 110LT has that cute groove molded in it representing the front bolster and it wraps over the spine to the lock bar. If they grind the spine which removes the humps and finishes everything flush, they will remove that groove.
So, had they not included that little groove they probably could/would have ground the spine to remove the hump.
Your photo again:
The hump doesn't really bother me for anything more than aesthetics. It might even provide a bit of traction on the spine. If I'm going to file it off of mine, I'll probably open the blade partially then file it and check it with the blade over and over until they fit flush with the blade open.
The only problem with this is that you might create another problem to work out. Where the hump was will now have a different finish than the rest of the lock bar. Do you try to polish the whole thing to match, or just leave that little mismatched finish issue?
I think I might leave it.
It's not rustGot a pair yesterday. Love the red handles and excited to have these in CPM154.
Bit of blade play in all directions, and I hope someday there is an adjustable pivot in these things, but not a dealbreaker by any means.
But, yeah, whats up with the "rust" in the nail nick?
funny.....Those bumps are shock absorbers
