There's a lot of confusion about first aid for snakebite. Before you rely on anyone's advice, though, you may find it helpful to read for yourself the results of original research on the subject, and not just a medical journal review article.
Keep in mind, though, that I believe that it was not until 2004 that the first experiments on humans were conducted with snakebite Sawyer's suction cups applied after volunteers were injected with mock venom.
The study confirmed earlier porcine model experiments which showed that the amount of venom removed was negligible. Moreover, there are articles published in medical journals which show that the suction devices exacerbate the wound in actual snakebite victims.
Needless to say, Sawyer Products' consultant, Dr. William W. Forgey, said, "You're not testing it accurately if you're not using the real venom." What Forgery failed to mention was that in 2001 Alberts, et al. did conduct an experiment with real rattlesnake venom on pigs and found that suction was ineffective.
Forgey contends, however, that if the Sawyer's product is used promptly, it will suck out 30% of the venom. However, he is relying on a study which has never been published, let alone in a peer reviewed medical journal. Forgery says that Sawyer Products cannot afford to do its own research. Source:
http://tinyurl.com/2yxvrj
Moreover, Bush et al, wrote in the Annals of Emergency Medicine ( 2004;43:187-188) that "in another study, Extractors were applied to 2 human patients immediately after rattlesnake envenomations, and the device was left in place until its cup filled with serosanguinous fluid 5 times, although the authors do not specify the volume(s) of fluid obtained. The concentration of venom was measured in the fluid removed using an enzyme-linked immunosorbent assay.[Bronstein AC, Russell FE, Sullivan JB. Negative pressure suction in the field treatment of rattlesnake bite victims [abstract]. Vet Hum Toxicol. 1986;28:485}].
There were no control subjects, and this study has only been published in abstract form. Ironically, this abstract is cited amongst the main supporting evidence for the Extractor.[Gold BS. Snake venom extractors: a valuable first aid tool [letter]. Vet Hum Toxicol. 1993;35:255; Norris RL. A call for snakebite research. Wilderness Environ Med. 2000;11:149-151].
However, a closer review of the results reveals that the concentration of venom in the serosanguinous fluid removed was only about 1/10,000th the concentration of rattlesnake venom.
Based on the best medical evidence, here's what the Red Cross recommends:
From the 2005 First Aid Science Advisory Board Evidence Evaluation Conference, hosted by the American Heart Association and the American Red Cross in Dallas, Texas, January 2324, 2005.
"Consensus on Science
Although some first aid texts recommend that rescuers must remove venom from a snakebite, a controlled animal study (LOE 6)107 showed no clinical benefit and earlier death in animals with snakebites that were treated with suction compared with animals with snakebites treated without suction. Two subsequent studies (LOE 5108; LOE 6109) showed that the application of suction resulted in the removal of some injected venom, but these reports did not examine clinical outcome. The use of a suction device on rattlesnake envenomation in a porcine model (LOE 6)110 showed no benefit and suggested injury may occur with suction. A simulated snakebite study in human volunteers (LOE 5)111 determined that a suction device recovered virtually no mock venom.
If a snakebite is from an elapid (eg, coral) snake, first aid treatment includes application of pressure immobilization. The landmark article by Sutherland (LOE 6)112 showed that pressure immobilization after elapid snakebites retarded venom uptake in monkeys. In a human study Howarth (LOE 3)113 showed that lymphatic flow and mock venom uptake can be safely reduced by proper application of pressure (40 to 70 mm Hg for upper limbs, 55 to 70 mm Hg for lower limbs) and immobilization and that either alone is insufficient. Pressure bandages should not be applied too tightly because they will restrict blood flow. A recent study in pigs (LOE 6)114 documented improved survival rates with application of moderate pressure and immobilization.
Treatment Recommendation
First aid providers should not apply suction to snakebite envenomation sites.
Properly performed pressure immobilization is recommended for first aid treatment of elapid snakebites. The first aid provider creates this pressure by applying a snug bandage that allows a finger to slip under the bandage.
References
Leopold RS, Huber GS. Ineffectiveness of suction in removing snake venom from open wounds. U S Armed Forces Med J. 1960; 11: 682685.
Bronstein AC, Russell FE, Sullivan JB. Negative pressure suction in the field treatment of rattlesnake bite victims. Vet Hum Toxicol. 1986; 28: 485
Bronstein A, Russell F, Sullivan J, Egen N, Rumack B. Negative pressure suction in field treatment of rattlesnake bite. Vet Hum Toxicol. 1985; 28: 297.
Bush SP, Hegewald KG, Green SM, Cardwell MD, Hayes WK. Effects of a negative pressure venom extraction device (Extractor) on local tissue injury after artificial rattlesnake envenomation in a porcine model. Wilderness Environ Med. 2000; 11: 180188.
Alberts MB, Shalit M, LoGalbo F. Suction for venomous snakebite: a study of "mock venom" extraction in a human model. Ann Emerg Med. 2004; 43: 181186.
Sutherland SK, Coulter AR, Harris RD. Rationalisation of first-aid measures for elapid snakebite. Lancet. 1979; 1: 183185.
Howarth DM, Southee AE, Whyte IM. Lymphatic flow rates and first-aid in simulated peripheral snake or spider envenomation. Med J Aust. 1994; 161: 695700.
German BT, Hack JB, Brewer K, Meggs WJ. Pressure-immobilization bandages delay toxicity in a porcine model of eastern coral snake (Micrurus fulvius fulvius) envenomation. Ann Emerg Med. 2005; 45: 603608.
Source: http://jfas.umin.ac.jp/G2005/Part%2010.doc"
