- Dec 3, 2010
You can get the Smith's stones at wally world?
yeppers, check the sporting good isle. They even should have smiths guided sharpeners like the lansky and other stuff like that.
That's cold, man. Just rub everyone's nose in it, why don't you.I don't.![]()
I would think you'd want something bigger for that sort of thing; I have a set of the 4" DMT stones (not X-coarse) and even reprofiling a 3-4" blade is tricky. I generally resort to water stones for bigger blades, just because of the surface area of the stone, and I already have them from sharpening woodworking tools. DMT makes some two sided bench stones; the Duo-Sharp+ is the least expensive and gives you two different grits, one on each side plus a little area of continuous diamond for small stuff. I've heard they last pretty much forever. I used to use the 4" ones at the ski shop I managed and never had to replace them in the two years (and thousands of skis) I worked there, and they were already a couple years old when I started. My 2¢.That looks like a great option, too.
How necessary is a coarse/fine diamond stone if I also have a sharpmaker to finish a blade off with?
My thought process was:
1. Diamond stone for easy, effective, quick reprofiles.
2. move to the norton india stone
3. finish on sharpmaker
Thats good for it Guyon, flush it out.
You're too far from Sloan's to be gambling like that.
At least the outside temp is above freezing...
I need a Browning M-2
Put a ton of time and money into fixing up the Durango this past year, and now the head gaskets are shot and due that that, sounds like bearings might be too. Time to call it quits on this one.
