These are personal preference so calling BS on one's personal preference makes no sense. I happen to think that the XM-18 feels better in the hand than either the SnG or the SMF. As far as the grind goes, well I had a flat ground tanto SnG that couldn't cut anything because the edge was so obtuse. The flat ground drop point SnG's and SMF's probably do make better slicers than the XM-18's Spanto grind... Once you reprofile the edge of the Striders so that they are actually even and cut properly.
The SMF has the ergonomics of a brick. The blade is OK except for the 3.5" cutting edge.
You can't call blade geometry performance a "preference." Hold the blades up and compare, and if that doesn't help cut something.
Actual edge geometry is easily changeable with a XC DMT stone. Considering the community here it's easily believeable that the can and will be finished to the users liking. If you got a SnG with a bad edge, either (a) sharpen it or (b) send it back.
Normally, I would say you are correct. Normally, I would say that you can't call blade geometry performance a preference, but when you are talking about Strider knives, it is. Like I've said before, I've had to reprofile the edge on four of the six different Striders that I've owned. You're telling me this should be a normal thing? I receive a $400 knife and I have to either send it back or reprofile the edge because they can't get it right at the factory? You want to talk about BS...Out of the box, both of the XM-18's that I've received with a factory edge were sharper and would outperform the edge any of the Strider's that I've received with the factory edge still intact.
Also, I would like to say that the grind itself is of personal preference. While some may like the flat ground or 3/4 hollow grind that the SnG or SMF is offered in, others may prefer the spanto grind. Just because you don't like the spanto grind for your personal use doesn't mean everyone falls in the line of your thinking. Maybe one prefers the spanto grind for what I'm going to use the knife for.
Some people feel their $80k didn't come with the right tires, so they spend a couple bucks to change them. Factory's fault?
You may prefer one blade grind over the other, but you can't say that the spanto slices better then a FFG. At least the spanto I handled. I heard he now makes a couple different grinds, I haven't handled them all. The passaround killed any desire for an XM-18 in me.
Here we go with another knife and car comparison.I'd just like to say that I'm talking about a $400 knife and not an $80,000 car, but I'll play along.
So basically what you are saying is that Strider putting a garbage edge on their production knives is the same as BMW not having the tire of your preference? How is this even a comparison? I would say the comparison would be better stated like this: Strider putting a garbage edge on their production knives would be the same as BMW delivering your brand new car with the exact tires you want, but there's huge holes in the tires. The shoddy lockup with bladeplay can be compared to your new BMW's brakes not working properly and the tires wobbling all over the place. That grindy, not so smooth opening and closing of the new Strider can be compared to your brand new BMW's gears grinding terribly even though you're shifting as you should be. Oh, and that blade that's not quite centered? That's the crappy alignment on your brand new Beemer.
See, here's the issue. I've had zero of those issues with my Striders. No lockup issues. No rough opening. Everything tight and centered. A bit obtuse blade grind, sure, but nothing past that.
Great vids cziv :thumbup:
Thanks for doing it.
Each work deserves the best knife for doing itSlicers for slicing, cutters for cutting, etc.
..so..Spidies for slicing, Striders for fixing them and admiring all after, Hinderers for relying on them 100% and for passing them around to Strider folk
You're a lucky man. Now I know who gets all the good ones.![]()
Your SnG looks broken in already. That doesn't look like a factory edge either.
Like most have said get the XM-18. The SNG is a tank. That is about all I can say for it. You never know if you will get a good one. Biggest SNG problems is the pivot is way to tight because the tolerances are terrible. You are supposed to open and close it 10000 times before it gets smooth. By that time the blade detent is worn flat and the damn things just fall open. At that point you can send it back to the factory to get put back to gorilla tight and likely something else will get f'ed up. I tried several times to get decent customer service from Strider. The service is terrible. A 100% no questions asked warranty isnt worth a damn if the product is garbage and the customer service is garbage.
Sorry that was a rant. You will pay the same for either. Some get lucky others dont. You dont have to think twice about an XM-18 being perfect everytime.
