- Nov 13, 2015
Spine whacking causes stress on a folding knife that represent all the forces from using a folding knife in a manner other than what it was intended for.
Get a bit prac-tac aren't we?
... I like knowing which of my folding knives will likely hold up to the kinds of things I never want to do![]()
Even Sal advised a LIGHT spine tap here:
http://www.bladeforums.com/forums/s...ength-Reliability-and-Spine-Whack-tests/page2
"1st, inspect the lock. dirt in a lock-back well will cause a defeat that will "cap" the adjacent corners of the tang & lock and cause permanent damage.
Then a light spine tap.
I have seen more than one knife that was destroyed by spine whacking and the customer blamed it on the knife and expected a replacement.
sal"
Ankerson in same thread:
"I see no problem with spine whacking because if the lock is really strong it should be able to handle it. I test all my folders this way, if they fail they go back where they came from. I am not light about it either, I whack them pretty good about 10 times with a thick leather glove on
I just look at it like this:
Knives are replaceable, your fingers are not. "
Well, if one of your tactical techniques is to whack a bad guy on the head with the spine of your knife, you are outta luck.
IMO, if you cut "down" you will be fine. :thumbup:
Maybe one day they will come out with a hard use knife that doesn't fold. Somebody should get on that...probably make a ton of money.![]()
Not to mention, a lot of military people where mobility is key don't carry fixed blades anymore. I mean, I understand how it is not a typical requirement for a knife however, this is classified as "hard use tactical knife" so I expect more than a regular knife as it costs more and is also heavier. But, I can think of many tasks that a knife could be used in a stabbing motion if you hit slightly above the tip on the spine could cause a knife to fold on your finger(and frankly if you are doing it hard enough you could loose a finger). That is my thinking, and to me that is dangerous.
The irony here is Gideons with $200 plus ZTs and he cant stab anything, and then these nuts on the bus with their crapo gas station special knives are stabbing folks with impunity. That hurts.
Word gone topsy turvy.
Damn, more trolling on this thread than a fishing forum. A guy asks a question and out come the snarkers, most of whom don't seem to have actually read the whole post. I test my gear because sometimes things happen to put it under stress. A knife isn't a hammer, but I have worked in confined areas where the occasional bump is going to happen. Or the only tool I have on me that can do the task at hand isn't exactly the ideal tool for the job, because I don't carry a whole freaking rollaway with me wherever I go. It would be stupid to put a big hit on your blade, but I think it's shortsighted to not check the lockup with a tap from time to time. That's it for me, no more feeding the trolls.
