Again, the issue is the lock, not what it's attached to. If you have to kick it in, then the lock did it's job. If you kick it in and the lock, frame, or other part isn't damaged, it is a very poor lock. If you can put a pipe wrench on a locked doors knob and open it without breaking the knob or lock, it's not a good lock.
Only in the knife world can a lock let a blade close, still function just as it did before, and it's considered useless or abusive to have tried the lock. In some circles, it is even put forth that one should treat any folder as though it didn't have a lock, even when there is one.
I don't personally consider it abusive, although I do consider it useless, but that's just me. I could say that if you have to "whack the spine with x amount of force" the lock still did its job, just as for your example, the door lock did its job even though Blues kicked it down.
The gun safe stops being useful as a safe if the lock doesn't work--though I guess it still makes a fine container.
A door and a knife both function as intended regardless of the lock. That's the big difference for most of us who don't "get" the spine whack tests.
Don't get me wrong, I'd be annoyed if any of my locking knives failed in what I consider normal use. And probably more than annoyed if a light accidental tap on the spine in the course of normal use caused the lock to fail. I just personally don't see the relevance of more than a tap, for testing, since I can't see myself accidentally whacking the spine with a great amount of force. But, anything is possibly.
The issue is fun to debate, but it's one of those things that usually just gets us further entrenched.
That said, I see the merit in a light tap, as Sal suggested in one thread.
But I'll probably never "get" those who whack it hard as can be a dozen times and, if met with failure, send the knife back. But, that's okay, I don't need to get it.
