Sal Glesser
Moderator
- Dec 27, 1998
I must confess that I have been influenced by the persistence of RLR (Spyderco site forum) and J.Davey (Bladeforum Spyderco forum) to re-think the SPOT concept and design.
The original SPOT design was the result of much comversation on the forums.
For what it was designed to do, the Perrin finger hole and the Spyderco ergos work well.
1. The knife is not likely to be dropped.
2. The hand is not likely to slide down onto the blade.
3. The action required for use is a natural motion.
The bladed shape needed to be addressed and after much thought, I will concede that the warncliffe blade shape would function quite well. Again, thank RLR & J.Davey. A "leaf" would be my second choice.
I've decided to make a few pattern concept models with the warncliffe to see if the shape and size needs modification. The design as drawn is very similar to the Spot. Slight ergo mods. The blade is a full flat ground warncliffe about 2.25" long.
We'll cut out a few and treat it as an "R&D test".
RLR & J.Davey; if you would be so kind as to email to me your mailing address, I will send each of you one. You can help.
I will also be addessing the sheath/deployment system. I think that a compact sheath, with a clip system and "thumb-push" deployment method that we use on our other Boltaron sheaths would be best. Although opinions are appreciated.
I think a neck hanging system is not as effective as a fixed location that doesn't move or dangle. Deployment ease and speed being important. Immediate access from any position.
Thoughts?
sal
The entire "business chain" from; raw materials, manufacturing, marketing, selling, distributing, shipping, warrantees, insurance, credit, etc. ALL EXISTS to service the ELU (End Line User). Remove the ELU from the equation and the entire business chain falls like a house of cards. We all work for you!
Thoughts?
sal
