OK. I got my SPOT a week ago, and I'm loving it. I can't stop playing with it. It fits my hand almost perfectly, which supprised the hell out of me. Looking at the plain picture of the knife, I couldn't imagine how anyone could think this knife was even remotely ergonomical. I came across a picture (in a LaGriffe thread I think) that showed the knife gripped, and it was like an epiphany. Instead of fingers being all jammed up higgaldy-piggaldy, it looked like it fit within a normal fist. Sure enough, it fits in my hand like it's not even there.
It was much smaller than I'd expected. I knew it was small, and even though there was the picture of it being held, I never appreciated how small it was. I don't consider that a bad thing though, the blade definitely seems like it'd get the job done. The handle wasn't too small though, it fits me perfectly.
I liked it so much that I ordered a plain edge and another SE one. I might order another PE one too, if I like it for utility use.
My thoughts on a new/improved model:
I'm definitely supportive of a larger wharncliffe blade. I'd also like to see a larger reverse-S curve, but it seems like the original shape wasn't overly well received, leading to its discontinuance. I think a hawkbill of some sort is a great blade shape for a knife of this size, since obviously penetration isn't much of an issue with so small a blade. I'm hardly an expert on this sort of thing though.
I like the neck sheath (actually, this is my first experience with Kydex), but for me, neck carry isn't my first option. It works fine strapped to my backpack with paracord, but of course, I'd like something more secure. I've been thinking about having a third-party sheath made. Some sort of multi-carry sheath would be the best IMO, although it seems like things of this nature, that do many things, excell at none. Maybe an option of different carry sheaths at purchase would work.
For me, the ergos are near perfect. However, my hands are skinny, and I can easilly see how larger hands might not like the small grip. OTOH, as it is, the SPOT offers a more secure grip than many other neck knives.
If I were to make my own knife, I'd do it this way:
2-2.25" Reverse S Curve blade. The last 1/2" of the tip would be hawkbilled, and it'd be a bit pointier at the tip to allow easier stabbing.
Same micarta handles as on the VG-10 model.
Same size handle and finger hole. However, I'd add a pinky finger hole. This would add more grip area, more secure retention, and possible "brass knuckle" impact use. I suppose this would also make it rather like a karambit (not like I'd know how to use a karambit), since it would very easy to hold in a reverse grip.
Of course, this might push the knife beyond the concept of a neck knife (small, light, and easily concealable), being probably 2 inches longer and an ounce heavier.
Whatever you decide Sal/Spyderco, you can count on me being a customer at least once if you put out this new SPOT.
BTW, I've got a Ronin on the way too.
